[GSAS-II] GSAS-II mail announcement
Robert Von Dreele
vondreele at anl.gov
Tue Jul 3 09:50:04 CDT 2012
Hi all,
This is to let you know (if you haven't already heard) that the
new GSAS-II software is available for you folks to try out. GSAS-II is a
complete crystallographic package in development that will run on
Windows, Linux & MacOSX machines (developed on Windows so best there).
It makes extensive use of computer graphics, both as a user interface
and to display results. To find information use
http://tinyurl.com/GSASII, or just Google "GSAS-II"; it probably will be
the first thing listed.
GSAS-II will read & process both x-ray and neutron (CW only) powder data
in most any of the old GSAS file formats and single crystal data in IUCr
CIF format. It can also read and process (e.g. calibrate & integrate)
2-D image powder data. Powder data processing includes peak fitting &
indexing as well as Rietveld & Pawley refinement. Single crystal data
can be used in combined or separate refinements as well. The system
includes Fourier map preparation & display, peak picking and crystal
structure display in a variety of forms (balls, balls & sticks,
ellipsoids, polyhedra), as well as distance/angle/torsion/plane geometry
results calculations with esds for the resultant data values. Constraint
relations and equations may be applied upon parameters as needed. There
is also a scheme for charge flipping structure solution for either
single crystal or powder diffraction data (some further development is
needed to complete this). More work is also planned to add facilities
for restraints and rigid body refinement. Plans for handling neutron TOF
data and analysis of magnetic/incommensurate/protein structures are in
consideration.
GSAS-II distributed via a subversion server here at Argonne Natl. Lab.
and consists of python source code, some fortran source code (compiled
for most platforms) and library modules, a suite of tutorials, and
example data files. It requires python 2.7+ (but not python 3.+) and
certain python packages (wxPython, numpy, scipy, matplotlib & pyOpenGL).
Please see the wiki pages for full installation & operating instructions.
If you give it a try, please let us know your experiences and especially
if you find bugs & errors. Suggestions are welcome. There is a also
brand new GSAS-II mailing list, see
http://www.aps.anl.gov/mailman/listinfo/GSAS-II; we request users sign up.
Bob Von Dreele & Brian Toby
An embedded and charset-unspecified text was scrubbed...
URL: <http://www.aps.anl.gov/pipermail/gsas-ii/attachments/20120703/9ad37c4f/attachment.txt>
More information about the GSAS-II
