[GSAS-II] libgfortran.so.1 missing in ubuntu 12.04 (64 bit)
Huynh Khuong
huynh.kim.khuong at gmail.com
Thu Nov 8 10:00:45 CST 2012
Dear all,
I installed GSAS-II from svn following the instruction from here
https://subversion.xor.aps.anl.gov/trac/pyGSAS
After the installation, I tried to run GSAS-II and ended up with this error:
khuong at khuong-SVS13A15GGB:/opt/gsas-II$ python GSASII.py
GSAS-II binary directory: /opt/gsas-II/binlinux64-2.7
Traceback (most recent call last):
File "GSASII.py", line 60, in <module>
import GSASIIIO as G2IO
File "/opt/gsas-II/GSASIIIO.py", line 20, in <module>
import GSASIIgrid as G2gd
File "/opt/gsas-II/GSASIIgrid.py", line 21, in <module>
import GSASIImath as G2mth
File "/opt/gsas-II/GSASIImath.py", line 25, in <module>
import GSASIIspc as G2spc
File "/opt/gsas-II/GSASIIspc.py", line 19, in <module>
import pyspg
ImportError: libgfortran.so.1: cannot open shared object file: No such
file or directory
I got libgfortran3 installed in from repository in my PC. My system is
Ubuntu 12.04 64 bit.
I do not install EPD packages. Only scipy, numpy, and matplotlib are
installed.
Another information: I sucessfully used GSAS-II in another PC under
Ubuntu 12.04 64 bit some months ago. I don't understand why this error
happen this time.
Any help will be very appreciate.
Best,
Khuong Huynh
URL: <http://www.aps.anl.gov/pipermail/gsas-ii/attachments/20121109/8a877789/attachment.html>
More information about the GSAS-II
