[GSAS-II] roughness function
afalent at gwdg.de
afalent at gwdg.de
Wed Dec 11 10:48:48 CST 2013
Well, it might be a silly comment but if you have some older prm file you can always edit it by hand in any text editor. The format is very easy to understand. It is not as nice and easy as in gsas but if you do not rubbish the formating you can quickly create any configuration you desire.
Good luck :)
Andrzej
"Toby, Brian H." <toby at anl.gov> schrieb:
>Monika,
>I will need to check if a roughness parameter has been put into the
>code yet. I think not.
>GSAS-II is much more stable than GSAS and does not have damping because
>it is not needed.
>There are a number of tutorials that can be found in the help menu or
>here: https://subversion.xray.aps.anl.gov/trac/pyGSAS
>GSAS-II can read GSAS instrument parameter files. It does offer a more
>straightforward format, but I don't think that has been documented yet.
>You can write parameters out with that format though. Note that when
>asked to supply a instrument parameter file, one can press "Cancel" and
>then select from a default.
>One can export results in various formats from the menu with that name
>and how to write code to support other formats is documented.
>There is a need for much more documentation, but at present Bob and I
>are putting much more effort into writing more code. Someday we will
>catch up, but volunteers are much welcome.
>Brian
>On Dec 11, 2013, at 10:21 AM, Monica Bolívar wrote:
>Dear Colleagues,
>I am new in GSAS II and now I start with some refinements in materials
>previously refined in GSAS. I noticed that there are many differences
>between GSAS and GSAS II results. Mainly, because some parameters that
>I refined in GSAS I could not find in GSAS II. For instance, I did not
>see how to refine roughness. Another question comes from the
>possibility of acting with damping factors.
>I really have many other questions like how to create the instrument
>file, how to export the data results, how to identify the hkl indices
>in the plot, etc.. However, a tutorial help to resolved some of these
>concerns. Someone knows is there a tutorial for GSASII?
>I would appreciate any help for a better understanding and use of
>GSASII.
>Thanks in advance,
>Mónica
>Mónica Esperanza Bolívar Guarín
>Departamento de Física - ICEx, UFMG
>Laboratório de Cristalografia
>Av. Antônio Carlos 6627, Pampulha
>Caixa Postal 702
>Belo Horizonte, MG
>30123-970
>Brasil
>_______________________________________________
>GSAS-II mailing list
>GSAS-II at mailman.aps.anl.gov<mailto:GSAS-II at mailman.aps.anl.gov>
>https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
>Brian H. Toby, Ph.D. office: 630-252-5488
>Senior Physicist/Section Head for Scientific Software
>Advanced Photon Source
>9700 S. Cass Ave, Bldg. 401/B4192 work cell: 630-327-8426
>Argonne National Laboratory
>Argonne, IL 60439-4856 e-mail: brian dot toby at anl dot gov
>"We will restore science to its rightful place, and wield technology's
>wonders... We will harness the sun and the winds and the soil to fuel
>our cars and run our factories... All this we can do. All this we will
>do."
Diese Nachricht wurde von meinem Android-Mobiltelefon mit K-9 Mail gesendet.
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20131211/d5279c78/attachment-0001.html>
More information about the GSAS-II
