[GSAS-II] Data Exclusion in GSAS-2
Toby, Brian H.
toby at anl.gov
Sat Mar 29 11:26:13 CDT 2014
Did you get a reply from Bob Vondreele suggesting that you add a background peak? This would be a better route than excluding the data. (To do that, change the "No. Peaks" at bottom of background tab and set the position to the appropriate location. Refine sig or gam and int before pos).
If you really want to exclude data, follow the tool-tip on the tree window when you select the add exclude menu item: click on the first data point to exclude and then drag the mouse over the range to exclude. You can then move the region by editing the numbers or dragging the lines.
Brian
On Mar 28, 2014, at 12:15 AM, Shoaib Muhammad wrote:
I am trying to refine Metal Oxide HRPD data which has bad ground as shown in attached screenshot. I want to exclude part of this data 20-25 degree. In GSAS2 tree menu, under PWDR section, in Limits and then Edit, I can find “Add Exclude” but nothing happens when I click this feature. I would be very thankful if anybody could guide me how to use this feature.
/Shoaib
<Capture.png>_______________________________________________
GSAS-II mailing list
GSAS-II at mailman.aps.anl.gov<mailto:GSAS-II at mailman.aps.anl.gov>
https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
Brian H. Toby, Ph.D. office: 630-252-5488
Senior Physicist/Section Head for Scientific Software
Advanced Photon Source
9700 S. Cass Ave, Bldg. 401/B4192 work cell: 630-327-8426
Argonne National Laboratory
Argonne, IL 60439-4856 e-mail: brian dot toby at anl dot gov
"We will restore science to its rightful place, and wield technology's wonders... We will harness the sun and the winds and the soil to fuel our cars and run our factories... All this we can do. All this we will do."
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20140329/fc8b364e/attachment.html>
More information about the GSAS-II
