[GSAS-II] Simulating a diffraction pattern in GSASII
Shoaib Muhammad
mshoaibce at gmail.com
Wed May 21 01:04:10 CDT 2014
Dear All,
I am trying to simulate a neutron diffraction pattern in GSAS2. To do this,
I have first introduced a phase by using a CIF file, imported an instrument
resolution file and selected suitable scale. By running the refinement cycle
I can see the expected simulated pattern in GSASII plot window. When I try
to export this pattern (to use in plotting software) by "Export", "Powder
Data as" and then CSV or txt, I get pattern only from 15 to 20 degree
although in preview windows I can see my selected range, that is 15 to 140
degree. Kindly let me know the correct procedure to export this simulated
pattern.
I have attached the gpx and output txt file.
/Shoaib
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20140521/8e23840d/attachment-0001.html>
Desc: not available
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20140521/8e23840d/attachment-0001.obj>
An embedded and charset-unspecified text was scrubbed...
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20140521/8e23840d/attachment-0001.txt>
More information about the GSAS-II
