[GSAS-II] GSAS-II questions
Bell, Anthony
Anthony.Bell at shu.ac.uk
Mon Jul 18 09:48:31 CDT 2016
Dear all
Thanks to the replies to my emails last week. I am still struggling up the learning curve with GSAS-II.
I have done two of the tutorials with GSAS-II so I am now returning to some of my own data, recently collected for me on I11 at diamond light source. I had done a reasonable refinement using laboratory XRD data here in Sheffield, I am now trying this refinement with synchrotron data to get a better refined crystal structure. My FULLPROF refinement of these data was reasonably good but not great, as I wasn't sure of some of the peak width terms to use for I11. I knew with GSAS I could include an instrument parameter file which would hopefully give me a better starting model for the peak width terms.
Two questions.
Is it possible to refine some peak asymmetry terms in the peak width parameters in GSAS-II?
My synchrotron data is on a synthetic mineral sample with tetrahedrally coordinated silicate framework structure. I wish to put in Si-O bond restraints. I know that there should be 4 Si-O bonds per tetrahedrally coordinates silicon, each bond should be about 1.61 angstroms in length. However, when I add restraints not all of the silicon atoms have 4 Si-O bond restraints calculated, some only have 3 or 2 Si-O bond restraints? Is there some way of manually adding restraints? My previous FULLPROF refinement had 4 Si-O bond length restraints per Si, is it possible to import restraints from a FULLPROF input file?
Thanks in advance
Dr. Tony Bell
Senior X-ray Technician
Materials and Research Engineering Institute
Sheffield Hallam University
City Campus
Howard Street
Sheffield
S1 1WB
Anthony.Bell at shu.ac.uk<mailto:Anthony.Bell at shu.ac.uk>
0114 225 3401
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20160718/0de8f70f/attachment.html>
More information about the GSAS-II
