[GSAS-II] I can not export CIF-full in GSAS-II
Edward Ebner Avila Sosa
eavila at ivic.gob.ve
Thu Nov 3 10:01:29 CDT 2016
Hi everyone,
I have a problem with GSAS-II program for export full CIF. This generate me the following errors:
Writing CIF output to file LaFeAlO3_3.cif...
Traceback (most recent call last):
File "C:\GSASII\GSASII.py", line 133, in MenuBinding
log.InvokeMenuCommand(event.GetId(),self,event)
File "C:\GSASII\GSASIIlog.py", line 458, in InvokeMenuCommand
handler(event)
File "C:\GSASII\exports\G2export_CIF.py", line 2001, in Exporter
self._Exporter(event=event)
File "C:\GSASII\exports\G2export_CIF.py", line 1819, in _Exporter
str(self.shortauthorname) + "|" + instnam)
File "C:\GSASII\exports\G2export_CIF.py", line 71, in WriteCIFitem
self.fp.write('; '+value+'\n')
UnicodeEncodeError: 'ascii' codec can't encode character u'\xed' in position 69: ordinal not in range(128)
The GSAS-II version that I am using is 2511. Nevertheless, when I run the program and it ends, wirtes the lines down.
C:\Users\Edward\Documents\Colaboraciones\Raquel del Toro\Refinamiento_Perovskita\MyWorks\RAQ-61A\Rietveld_PDF2-3\LaFeAlO3_3.gpx
project save successful
Hessian refinement on 16 variables:
26 derivative time 0.0020
matrix modification needed; lambda now 1.0e-02
matrix modification needed; lambda now 1.0e-01
Cycle: 0, Time: 0.36s, Chi**2: 6881.7, Lambda: 0.01, Delta: -4.69e-05
converged
26 derivative time 0.0040
Read from file: C:\Users\Edward\Documents\Colaboraciones\Raquel del Toro\Refinamiento_Perovskita\MyWorks\RAQ-61A\Rietveld_PDF2-3\LaFeAlO3_3.bak86.gpx
Save to file : C:\Users\Edward\Documents\Colaboraciones\Raquel del Toro\Refinamiento_Perovskita\MyWorks\RAQ-61A\Rietveld_PDF2-3\LaFeAlO3_3.gpx
GPX file save successful
Refinement results are in file: C:\Users\Edward\Documents\Colaboraciones\Raquel del Toro\Refinamiento_Perovskita\MyWorks\RAQ-61A\Rietveld_PDF2-3\LaFeAlO3_3.lst
***** Refinement successful *****
GPX load successful. Last saved with GSAS-II version 2509
Particularly, catches me the last line. Is it GSAS-II version 2509 or 2511?
Finally, I reported a similar problem for export CIF-full in the GSAS-II version 2447 and and this was corrected in the version 2448. My problem now was to update and can not to retrun to version 2448.
GPX load successful. Last saved version With GSAS-II 2447
File "C: \ GSASII \ GSASII.py", line 133, in MenuBinding
log.InvokeMenuCommand (event.getID (), self, event)
File "C: \ GSASII \ GSASIIlog.py", line 458, in InvokeMenuCommand
handler (event)
File "C: \ GSASII \ exports \ G2export_CIF.py", line 2116, in Exporter
self._Exporter (self, event = event)
TypeError: _Exporter () got multiple values for keyword argument 'event'
Sincerely, Edward.
Dr. Edward E. Ávila S.
Laboratorio de Síntesis y Caracterización de Nuevos Materiales
Centro de Química
Instituto Venezolano de Investigaciones Científicas (IVIC)
Carretera Panamericana Km 11, Altos de Pipe
Telf.: (58) 0212-5041609
Cel-.: (58) 0426-2080809
correos-e: eavila at ivic.gob.ve; edebavso at gmail.com
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20161103/e6a1413e/attachment.html>
More information about the GSAS-II
