[GSAS-II] wrong intensities in calculated speactrum
Monica Dapiaggi
monica.dapiaggi at unimi.it
Fri Oct 20 07:58:37 CDT 2017
Did you check which origin of the cell you are using?
Best
Monica
Monica Dapiaggi
> Il giorno 20 ott 2017, alle ore 14:47, Ivo Alxneit <ivo.alxneit at psi.ch> ha scritto:
> Dear all
> I am trying to fit my diamond standard. The pattern shows 111, 220, and
> 311. In the fitted pattern I see the 222 reflection (I100 about 2) that
> is forbidden and I100=0 for the allowed 220 peak. Data from the cif file
> attached.
> my setup:
> (gsas) alxneit at PC12348:$ gsas
> GSAS-II binary directory: /fast_home/alxneit/GSAS-II/bin
> 4 values read from config file /fast_home/alxneit/GSAS-II/config.py
> Python module versions loaded:
> Python: 2.7.14
> wx: 3.0.0.0
> matplotlib: 2.0.2
> numpy: 1.13.3
> scipy: 0.19.1
> OpenGL: 3.1.1a1
> PIL.Image: 1.1.7
> Platform: linux2 64bit x86_64
> This is GSAS-II revision 3135
> Dr. Ivo Alxneit
> Catalysis for Energy Group
> Bioenergy and Catalysis Laboratory phone: +41 56 310 4092
> Paul Scherrer Institute fax: +41 56 310 2688
> CH-5232 Villigen gnupg key: 0x515E30C7
> Switzerland
> https://www.psi.ch/ceg/
> <diamond.cif>
> GSAS-II mailing list
> GSAS-II at mailman.aps.anl.gov
> https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
More information about the GSAS-II
