[GSAS-II] Workflow optimization
Ivo Alxneit
ivo.alxneit at psi.ch
Fri Nov 17 07:54:04 CST 2017
Dear all,
to optimize my work flow it would be nice if I could retain the size of
the two window at their user defined value. At present they are reset to
their default values after each refinement. Or, is this a deficiency of
the 'memory' GSetting backend?
In a similar respect, it would be nice to maintain the 'status' of the
plot window between refinements. They too are reset to their default
(display full plot) between refinements.
thanks
(gsas) alxneit at PC12348:~$ uname -a
Linux PC12348 4.4.0-98-generic #121-Ubuntu SMP Tue Oct 10 14:24:03 UTC
2017 x86_64 x86_64 x86_64 GNU/Linux
(gsas) alxneit at PC12348:~$ gsas
GSAS-II binary directory: /fast_home/alxneit/GSAS-II/bin
5 values read from config file /fast_home/alxneit/GSAS-II/config.py
Python module versions loaded:
Python: 2.7.14
wx: 3.0.0.0
matplotlib: 2.0.2
numpy: 1.13.3
scipy: 1.0.0
OpenGL: 3.1.1a1
PIL.Image: 1.1.7
Platform: linux264bitx86_64
This is GSAS-II revision 3149
GLib-GIO-Message: Using the 'memory' GSettings backend. Your settings
will not be saved or shared with other applications.
Dr. Ivo Alxneit
Catalysis for Energy Group
Bioenergy and Catalysis Laboratory phone: +41 56 310 4092
Paul Scherrer Institute fax: +41 56 310 2688
CH-5232 Villigen gnupg key: 0x515E30C7
Switzerland
https://www.psi.ch/ceg/
Desc: OpenPGP digital signature
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20171117/7a844349/attachment.sig>
More information about the GSAS-II
