[GSAS-II] moving tick marks
Toby, Brian H.
toby at anl.gov
Tue Jul 31 10:32:37 CDT 2018
Ondrej, yes you can drag them where you want them. Select either the PWDR or Reflection Lists tree item and then click down on them (left mouse button) and while holding the button down move them to where you want them to be. Note that 1st phase moves all of them and any other changes the spacing between the phases. Also the “s” button, for a square-root plot will reset the positions to more sensible places (press that twice to get back to the original.
Brian
On Jul 30, 2018, at 11:18 PM, MURANSKY, Ondrej <omz at ansto.gov.au<mailto:omz at ansto.gov.au>> wrote:
Dear Bob,
I have a “cosmetic” questions, is there a way to move the ticks identifying phases closer to the actual diffraction pattern. Please see below when I zoom-in ticks are nowhere to be seen. I tried to make them longer via “Set Config Variable” but that didn’t look that great either. Thank you for help.
Ondrej
Zoom out.
<image004.jpg>
Zoom in. Ticks no visible.
<image005.jpg>
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20180731/fe3cd1a0/attachment.html>
More information about the GSAS-II
