[GSAS-II] gsas2 version 3710 on linux does not open periodic table anymore
Lambert van Eijck - TNW L.vanEijck at tudelft.nl
Mon Oct 29 16:19:45 CDT 2018
another observation:
the other fields in the (same) atom row are editable, when needed, but
when clicking on the X,Y,Z fields, the selected value (0.0) appear
all-the-way-on-the-left, right in the "Name" column. I can change the
value, and hitting enter makes it appear under the (resp) X,Y,Z. Other
columns do not show this.
best regards, Lambert
On 10/29/18 10:10 PM, Lambert van Eijck wrote:
> Dear all,
> Since updating to 3710, I cannot open the periodic table anymore to
> select atom type:
> (GSASII.py:17340): Gtk-WARNING **: GModule
> (/usr/lib/x86_64-linux-gnu/gtk-2.0/2.10.0/immodules/im-ibus.so)
> initialization check failed: GLib version too old (micro mismatch)
> (GSASII.py:17340): Gtk-WARNING **: Loading IM context type 'ibus' failed
> Traceback (most recent call last):
>   File "/disk2/home/lve/src/g2conda/gsas/GSASII/GSASIIphsGUI.py", line
> 2853, in AtomTypeSelect
>     PE = G2elemGUI.PickElement(G2frame,ifMag=ifMag)
>   File "/disk2/home/lve/src/g2conda/gsas/GSASII/GSASIIElemGUI.py",
> line 65, in __init__
>     self._init_ctrls(parent,ifMag=ifMag)
> line 52, in _init_ctrls
>     tip=E[3],color=color)
> line 97, in ElButton
>     El.SetToolTip(tip)
>   File
> "/home/lve/src/g2conda/gsas/lib/python2.7/site-packages/wx-3.0-gtk2/wx/_core.py",
> line 11393, in SetToolTip
>     return _core_.Window_SetToolTip(*args, **kwargs)
> TypeError: in method 'Window_SetToolTip', expected argument 2 of type
> 'wxToolTip *'
> Installed GSAS-II version: 3710
> GSAS-II version on server: 3710
> It seems related to ToolTip, which I cannot simply switch off, I think.
> Any idea?
> I'm running an uptodate version of Debian-9.
> Lambert
More information about the GSAS-II mailing list
