[GSAS-II] Question about loading multi-histogram data into GSASIIscriptable
Ivo Alxneit ivo.alxneit at psi.ch
Fri Feb 1 01:14:46 CST 2019
Hi Long Yang
Hi all
I have a similar problem here. I cannot load a gpx file saved by GSAS-II
in scriptable. I tried with a project containing a single phase and a
single powder diffraction histogram as well as a project containing a
single phase and mny histograms for sequential refinement.
I am on Linux and GSAS-II installed via conda.
Any help appreciated.
Ivo
IPython console in Spyder
Python 3.7.1 | packaged by conda-forge | (default, Nov 13 2018, 18:33:04)
Type "copyright", "credits" or "license" for more information.
IPython 7.2.0 -- An enhanced Interactive Python.
In [1]: import os,sys
In [2]: sys.path.insert(0,"/home/alxneit/share/miniconda3/envs/gsas/GSASII")
In [3]: import GSASIIscriptable as G2sc
GSAS-II binary directory:
/home/alxneit/share/miniconda3/envs/gsas/GSASII/bindist
6 values read from config file
/home/alxneit/share/miniconda3/envs/gsas/GSASII/config.py
In [4]: p = G2sc.G2Project("s.gpx")
Traceback (most recent call last):
  File "<ipython-input-5-f663e6e6a7f4>", line 1, in <module>
  File
"/home/alxneit/share/miniconda3/envs/gsas/GSASII/GSASIIscriptable.py",
line 1264, in __init__
    self.data, self.names = LoadDictFromProjFile(gpxfile)
  File
line 675, in LoadDictFromProjFile
    raise IOError("Error reading file "+str(ProjFile)+". This is not a
GSAS-II .gpx file")
OSError: Error reading file s.gpx. This is not a GSAS-II .gpx file
(gsas) alxneit at triolite:~$ gsas s.gpx
Python module versions loaded:
  Python:     3.7.2
  wx:         4.0.4
  matplotlib: 3.0.2
  numpy:      1.15.4
  scipy:      1.1.0
  OpenGL:     3.1.1a1
  PIL.Image:  5.4.1
  Platform:   linux 64bit x86_64
This is GSAS-II revision 3785
GLib-GIO-Message: 13:15:42.229: Using the 'memory' GSettings backend.
Your settings will not be saved or shared with other applications.
loading from file: s.gpx
GPX load successful. Last saved with GSAS-II revision 3785
(gsas) alxneit at triolite:~$ conda list
# packages in environment at /home/alxneit/share/miniconda3/envs/gsas:
# Name                    Version                   Build  Channel
apr                       1.6.3                he40df45_0
asn1crypto                0.24.0                   py37_0
blas                      1.0                         mkl
ca-certificates           2018.12.5                     0
cairo                     1.14.12              h8948797_3
certifi                   2018.11.29               py37_0
cffi                      1.11.5           py37he75722e_1
chardet                   3.0.4                    py37_1
conda                     4.5.12                   py37_0
conda-env                 2.6.0                         1
cryptography              2.4.2            py37h1ba5d50_0
cycler                    0.10.0                   py37_0
cyrus-sasl                2.1.26               h82bf5a1_4
dbus                      1.13.6               h746ee38_0
expat                     2.2.6                he6710b0_0
fontconfig                2.13.0               h9420a91_0
freetype                  2.9.1                h8a8886c_1
fribidi                   1.0.5                h7b6447c_0
gettext                   0.19.8.1             hd7bead4_3
glib                      2.56.2               hd408876_0
graphite2                 1.3.13               h23475e2_0
gsas2pkg                  1.0.6                         0    briantoby
gst-plugins-base          1.14.0               hbbd80ab_1
gstreamer                 1.14.0               hb453b48_1
h5py                      2.9.0            py37h7918eee_0
harfbuzz                  1.8.8                hffaf4a1_0
hdf5                      1.10.4               hb1b8bf9_0
icu                       58.2                 h9c2bf20_1
idna                      2.8                      py37_0
imageio                   2.4.1                    py37_0
intel-openmp              2019.1                      144
jpeg                      9b                   h024ee3a_2
kiwisolver                1.0.1            py37hf484d3e_0
krb5                      1.16.1               h173b8e3_7
libdb                     6.1.26               he6710b0_0
libedit                   3.1.20181209         hc058e9b_0
libffi                    3.2.1                hd88cf55_4
libgcc-ng                 8.2.0                hdf63c60_1
libgfortran-ng            7.3.0                hdf63c60_0
libglu                    9.0.0                hf484d3e_1
libntlm                   1.4                  h14c3975_2
libpng                    1.6.36               hbc83047_0
libstdcxx-ng              8.2.0                hdf63c60_1
libtiff                   4.0.10            h2733197_1001
libutf8proc               2.1.1                h14c3975_0
libuuid                   1.0.3                h1bed415_2
libxcb                    1.13                 h1bed415_1
libxml2                   2.9.9                he19cac6_0
lz4-c                     1.8.1.2              h14c3975_0
matplotlib                3.0.2            py37h5429711_0
mkl                       2019.1                      144
mkl_fft                   1.0.10           py37ha843d7b_0
mkl_random                1.0.2            py37hd81dba3_0
ncurses                   6.1                  he6710b0_1
numpy                     1.15.4           py37h7e9f1db_0
numpy-base                1.15.4           py37hde5b4d6_0
olefile                   0.46                     py37_0
openssl                   1.1.1a               h7b6447c_0
pango                     1.42.4               h049681c_0
pcre                      8.42                 h439df22_0
pillow                    5.4.1            py37h34e0f95_0
pip                       18.1                     py37_0
pixman                    0.36.0               h7b6447c_0
pycosat                   0.6.3            py37h14c3975_0
pycparser                 2.19                     py37_0
pyopengl                  3.1.1a1                  py37_0
pyopenssl                 18.0.0                   py37_0
pyparsing                 2.3.1                    py37_0
pyqt                      5.9.2            py37h05f1152_2
pysocks                   1.6.8                    py37_0
python                    3.7.2                h0371630_0
python-dateutil           2.7.5                    py37_0
pytz                      2018.9                   py37_0
qt                        5.9.7                h5867ecd_1
readline                  7.0                  h7b6447c_5
requests                  2.21.0                   py37_0
ruamel_yaml               0.15.46          py37h14c3975_0
scipy                     1.1.0            py37h7c811a0_2
serf                      1.3.9                h1c830df_0
setuptools                40.6.3                   py37_0
sip                       4.19.8           py37hf484d3e_0
six                       1.12.0                   py37_0
sqlite                    3.26.0               h7b6447c_0
svn                       1.10.2               h52f66ed_0
tk                        8.6.8                hbc83047_0
tornado                   5.1.1            py37h7b6447c_0
urllib3                   1.24.1                   py37_0
wheel                     0.32.3                   py37_0
wxpython                  4.0.4            py37hc99224d_0
xz                        5.2.4                h14c3975_4
yaml                      0.1.7                had09818_2
zlib                      1.2.11               h7b6447c_3
On 31.01.19 20:13, Long Yang via GSAS-II wrote:
> Hi all,
> I am new to GSAS-II scriptable. I am trying to load the powder histogram data using `gpx.add_powder_histogram` but failed. The data file contains 6 banks TOF histograms together in one file. If use GSAS-II GUI, it can be loaded perfectly as in GSAS, but not work in GSASIIscriptable. The traceback is shown below.
> Anyone knows how to do it?
> Or do I have to cut the file into 6 pieces of individual files that one file is one bank histogram?
> Thank you!
> Bests,
> Long Yang
>   File "si.py", line 31, in <module>
>     hist = gpx.add_powder_histogram("nomad_si_data.gsa","NOMAD_2018A_shifter_20180606.instprm",fmthint="GSAS powder")
>   File "/Users/Dragon/anaconda/envs/gsas2/GSASII/GSASIIscriptable.py", line 1324, in add_powder_histogram
>     pwdrreaders = import_generic(datafile, PwdrDataReaders,fmthint=fmthint)
>   File "/Users/Dragon/anaconda/envs/gsas2/GSASII/GSASIIscriptable.py", line 991, in import_generic
>     raise G2ImportException("Not sure what data to select")
> GSASIIscriptable.G2ImportException: Not sure what data to select
> GSAS-II mailing list
> GSAS-II at aps.anl.gov
> https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
Dr. Ivo Alxneit
Catalysis for Energy Group
Bioenergy and Catalysis Laboratory        phone: +41 56 310 4092
Paul Scherrer Institute                     fax: +41 56 310 2688
CH-5232 Villigen                      gnupg key: 0x515E30C7
Switzerland
https://www.psi.ch/ceg/
Desc: OpenPGP digital signature
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20190201/779dbbfa/attachment.sig>
More information about the GSAS-II mailing list
