[GSAS-II] RB torsion sequence problem: 'rbId' is not defined
Arianna Lanza
Arianna.Lanza at iit.it
Thu Feb 21 13:54:38 CST 2019
Dear all,
I have recently installed the latest version of GSAS-II (I had a quite old one so thank you for the new features!).
I'm having troubles to define torsion angles in my rigid body "residue". I have the same error if I try on an old project, where I had successfully defined torsion sequences. I may have forgotten the procedure, but I cannot find it in the tutorials or old mails so please I need your help.
Below you see the error I get in the "black window".
GSAS-II binary directory: C:\Users\alanza\AppData\Local\Continuum\g2conda\GSASII\bindist
8 values read from config file C:\Users\alanza\AppData\Local\Continuum\g2conda\GSASII\config.pyc
Python module versions loaded:
Python: 2.7.12
wx: 3.0.0.0
matplotlib: 1.5.3
numpy: 1.11.2
scipy: 0.18.1
OpenGL: 3.1.1a1
PIL.Image: 3.4.2
Platform: win32 64bit AMD64
This is GSAS-II revision 3826
loading from file: E:\+VARIE\xxxx\xxxx\PXRD\UK\xxxx_UK_RB.gpx
GPX load successful. Last saved with GSAS-II revision 3825
Traceback (most recent call last):
File "C:\Users\alanza\AppData\Local\Continuum\g2conda\GSASII\GSASIIconstrGUI.py", line 1762, in OnDefineTorsSeq
rbData = data['Residue'][rbId]
NameError: global name 'rbId' is not defined
If anyone has experience with this I would appreciate any insight...
Thank you all in advance,
Arianna
PS: if you reply to all you help future users to not ask the same questions again and again...
,_,.-'´¨´'-.,_,.-'´¨´'-.,_,.-'´¨´'-.,_,,.-'´¨´'-.,_,.-'´¨´'-.,_,
Arianna Lanza, PhD
Center for Nanotechnology Innovation at NEST
Istituto Italiano di Tecnologia
Piazza San Silvestro, 12, 56127, PISA, Italy
+39 050 509732
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20190221/7a5eb95d/attachment.html>
More information about the GSAS-II
