[GSAS-II] Wrong data reported in "Sequential Results" table
Ivo Alxneit
ivo.alxneit at psi.ch
Thu Mar 21 02:36:23 CDT 2019
Dear all
GSAS-II binary directory: /fast_home/alxneit/miniconda3/envs/gsas/GSASII/bin
8 values read from config file /home/alxneit/.G2local/config.py
Python module versions loaded:
Python: 3.7.2
wx: 4.0.4
matplotlib: 3.0.2
numpy: 1.15.4
scipy: 1.2.0
OpenGL: 3.1.1a1
PIL.Image: 5.4.1
Platform: linux 64bit x86_64
This is GSAS-II revision 3857
I noticed that wrong numbers might be reported in the "Sequential
Refinements" table for some of the cell parameters.
In my case I refine in R-3ch, thus D11 and D33 define the
hydrostatic/elastic strain. I only refine D11 but have inserted
individual, non-zero values for D33 for the different histograms. The
Results table lists a-values that vary (correct) but constant values for
c, namely the values given for c in the Phases->General tab. So it seems
that only refined Dij values are used to calculate the unit cell
dimensions in the Results table and non-refined ones are assumed to be
zero. I also fear that the cell volumes reported are wrong too.
I assume (but did not check. I am far too unfamiliar with the code) that
the correct strain tensor is applied in the actual refinements (using
the individual non-refined, non-zero Dij of each histogram).
gruss
Dr. Ivo Alxneit
Catalysis for Energy Group
Bioenergy and Catalysis Laboratory phone: +41 56 310 4092
Paul Scherrer Institute fax: +41 56 310 2688
CH-5232 Villigen gnupg key: 0x515E30C7
Switzerland
https://www.psi.ch/ceg/
Desc: OpenPGP digital signature
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20190321/47e36200/attachment.sig>
More information about the GSAS-II
