[GSAS-II] Bug in export of sequential results
Ivo Alxneit ivo.alxneit at psi.ch
Thu Mar 28 11:00:39 CDT 2019
Dear all,
Exporting results of sequential refinements fails for histograms that do
not use all phases. Exporting (text, but CSV probably the same) WgtFract
of the attached gpx-files produces the errors below.
0:* -> fine
1:* -> error, one line in text file
2:* -> error, empty text file
GSAS-II binary directory: /fast_home/alxneit/miniconda3/envs/gsas/GSASII/bin
7 values read from config file /home/alxneit/.G2local/config.py
Python module versions loaded:
  Python:     3.7.2
  wx:         4.0.4
  matplotlib: 3.0.2
  numpy:      1.15.4
  scipy:      1.2.0
  OpenGL:     3.1.1a1
  PIL.Image:  5.4.1
  Platform:   linux 64bit x86_64
This is GSAS-II revision 3861
Starting Sequential Refinement
Refining with PWDR data_1690.xye
  wR =   45.82%, chi**2 =      41803.6, reduced chi**2 =  32.84, last
delta chi = 0.0035
Refining with PWDR data_2850.xye
  wR =   47.51%, chi**2 =      44309.8, reduced chi**2 =  34.81, last
delta chi = 0.0007
Read from file:/home/alxneit/local_data/gsas_test3/test.bak2.gpx
Save to file  :/home/alxneit/local_data/gsas_test3/test.gpx
GPX file merge completed
 Sequential refinement results are in file:
/home/alxneit/local_data/gsas_test3/test.lst
 ***** Sequential refinement successful *****
GPX load successful. Last saved with GSAS-II revision 3861
Traceback (most recent call last):
  File
"/fast_home/alxneit/miniconda3/envs/gsas/GSASII/GSASIIdataGUI.py", line
6233, in OnSaveSelSeq
    WriteSeq()
  File
6191, in WriteSeq
    line += ' %12.6f %12.6f '%(saveData[col][row],saveSigs[col][row])
TypeError: must be real number, not NoneType
  File
    WriteSeq()
  File
6191, in WriteSeq
The fix is probably to write one or two zeros to the file to fill the
collumn, so
if col in havesig:
	try:
	except TypeError:
			line += '0.0 0.0'
else:
	try
                        line += ' %12.6f '%saveData[col][row]
	except TypeError:
			line += '0.0'
and similar in Write_CSV()
gruss
Dr. Ivo Alxneit
Catalysis for Energy Group
Bioenergy and Catalysis Laboratory        phone: +41 56 310 4092
Paul Scherrer Institute                     fax: +41 56 310 2688
CH-5232 Villigen                      gnupg key: 0x515E30C7
Switzerland
https://www.psi.ch/ceg/
Desc: not available
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20190328/4f0d0507/attachment-0001.obj>
Desc: OpenPGP digital signature
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20190328/4f0d0507/attachment-0001.sig>
More information about the GSAS-II mailing list
