[GSAS-II] BUG report (and some fixes)
Ivo Alxneit
ivo.alxneit at psi.ch
Fri May 3 08:00:57 CDT 2019
Dear all
First line is omitted in plots of sequential results. In the attached
'test.gpx' only one data point is plotted (line 2). Exports are correct,
however.
In addition I have attached a patch that fixes three typos in
GSASIIscriptable:
- add missing definition for npsind
- use correct names for images read (please verify)
- use correct keyword in function call
pylint still reports the following undefined variables/arguments that I
could not fix as I do not understand the code too well:
E1120:2768,8: G2PwdrData.fit_fixed_points: No value for argument
'fixback' in function call
E0602:3063,23: G2PwdrData.LoadProfile: Undefined variable 'bank'
E0602:3975,28: G2Image.Integrate: Undefined variable 'Controls'
E0602:3978,34: G2Image.Integrate: Undefined variable 'waves'
E0602:4025,36: G2Image.Integrate: Undefined variable 'G2pdG'
E0602:4031,36: G2Image.Integrate: Undefined variable 'G2pdG'
My config (on linux)
$ GSAS-II binary directory:
/fast_home/alxneit/miniconda3/envs/gsas/GSASII/bin
7 values read from config file /home/alxneit/.G2local/config.py
Python module versions loaded:
Python: 3.7.3
wx: 4.0.4
matplotlib: 3.0.3
numpy: 1.16.3
scipy: 1.2.1
OpenGL: 3.1.1a1
PIL.Image: 6.0.0
Platform: linux 64bit x86_64
This is GSAS-II revision 3942
gruss / nice weekend
Dr. Ivo Alxneit
Catalysis for Energy Group
Bioenergy and Catalysis Laboratory phone: +41 56 310 4092
Paul Scherrer Institute fax: +41 56 310 2688
CH-5232 Villigen gnupg key: 0x515E30C7
Switzerland
https://www.psi.ch/ceg/
--- /fast_home/alxneit/miniconda3/envs/gsas/GSASII/GSASIIscriptable.py.old 2019-05-03 13:57:14.449904027 +0200
+++ /fast_home/alxneit/miniconda3/envs/gsas/GSASII/GSASIIscriptable.py 2019-05-03 14:51:59.497329406 +0200
@@ -752,6 +752,7 @@
'''Readers by reader type'''
exportersByExtension = {}
'''Specifies the list of extensions that are supported for Powder data export'''
+npsind = lambda x: np.sin(x*np.pi/180.)
def LoadG2fil():
@@ -1366,7 +1367,7 @@
formatName = dImgObj.data['Image Controls'].get('formatName','')
imagefile = dImgObj.data['data'][1]
ImageTag = None # fix this for multiimage files
- darkImg = G2fil.RereadImageData(ImageReaderlist,imagefile,ImageTag=ImageTag,FormatName=formatName)
+ darkImage = G2fil.RereadImageData(ImageReaderlist,imagefile,ImageTag=ImageTag,FormatName=formatName)
if darkImg is None:
raise Exception('Error reading dark image {}'.format(imagefile))
sumImg += np.array(darkImage*darkScale,dtype='int32')
@@ -1377,7 +1378,7 @@
formatName = bImgObj.data['Image Controls'].get('formatName','')
imagefile = bImgObj.data['data'][1]
- backImg = G2fil.RereadImageData(ImageReaderlist,imagefile,ImageTag=ImageTag,FormatName=formatName)
+ backImage = G2fil.RereadImageData(ImageReaderlist,imagefile,ImageTag=ImageTag,FormatName=formatName)
if backImage is None:
raise Exception('Error reading background image {}'.format(imagefile))
if darkImg:
@@ -4083,7 +4084,7 @@
associated with all histograms given.
- proj = G2Project(gpxname=args.filename)
+ proj = G2Project(gpxfile=args.filename)
hist_objs = []
if args.histograms:
Desc: not available
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20190503/b1d7e24e/attachment-0001.obj>
Desc: OpenPGP digital signature
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20190503/b1d7e24e/attachment-0001.sig>
More information about the GSAS-II
