[GSAS-II] potential bug at displayed structure
Falenty, Andrzej afalent at gwdg.de
Sun May 12 14:43:41 CDT 2019
Dear Bob and Brian,
I have encountered some strange error when interacting with the structure model. The error does not seem to have any apparent negative consequences. It just produce a number of error lines in the command window.
Python module versions loaded:
  Python:     2.7.12
  wx:         3.0.0.0
  matplotlib: 1.5.3
  numpy:      1.11.2
  scipy:      0.18.1
  OpenGL:     3.1.1a1
  PIL.Image:  3.4.2
  Platform:   win32 64bit AMD64
This is GSAS-II revision 3964
Phases > Atoms > Mouse hovered over the displayed structure
Original exception was:
Traceback (most recent call last):
  File "C:\g2conda\GSASII\GSASIIplot.py", line 8092, in OnMouseMove
    elif drawingData['showSlice']:
KeyError: 'showSlice'
Error in sys.excepthook:
  File "C:\g2conda\GSASII\GSASIIpath.py", line 737, in exceptHook
    import IPython.core
ImportError: No module named IPython.core
I have also one side question. I wonder if it would be possible to introduce a new option to the sequential refinement results. Facing hundreds of files in experimental series it is fairly inconvenient to type by hand sample information like temperature, pressure, humidity and so on. Would it be possible to update such data from csv or dat loaded to sequential results and later on updated for every pattern? It would make all sample parameters much more useful.
Best wishes
Andrzej
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20190512/27b42e94/attachment.html>
More information about the GSAS-II mailing list
