[GSAS-II] Unable to import powder data with Bruker RAW format
Schujman, Sandra
sschujman at sunypoly.edu
Wed May 15 12:44:31 CDT 2019
Hello,
I recently started using GSAS for powder diffraction refinement. I have a Bruker D8 Advance system. I was being able to open my files without any issue, and I had started the refinement procedure successfully, but a couple of updates later I am getting the error message posted at the bottom of this message.
Did any of the updates modified the RAW reader? Is this a GSAS bug? Should I uninstall the program and reinstall it?
Thank you for your program, and your help!
Sandra
General Structure Analysis System-II
by Robert B. Von Dreele and Brian H. Toby
Argonne National Laboratory(C), 2010
This product includes software developed by the UChicago Argonne, LLC,
as Operator of Argonne National Laboratory.
Please cite:
B.H. Toby and R.B. Von Dreele, J. Appl. Cryst. 46, 544-549 (2013)
for small angle use also cite:
R.B. Von Dreele, J. Appl. Cryst. 47, 1784-9 (2014)
for DIFFaX use also cite:
M.M.J. Treacy, J.M. Newsam and M.W. Deem,
Proc. Roy. Soc. Lond. 433A, 499-520 (1991)
C:\Users\ss626815\Desktop>C:\Users\ss626815\AppData\Local\Continuum\g2conda\python.exe C:\Users\ss626815\AppData\Local\Continuum\g2conda\GSASII\GSASII
.py ""
GSAS-II binary directory: C:\Users\ss626815\AppData\Local\Continuum\g2conda\GSASII\bindist
7 values read from config file C:\Users\ss626815\AppData\Local\Continuum\g2conda\GSASII\config.pyc
Python module versions loaded:
Python: 2.7.12
wx: 3.0.0.0
matplotlib: 1.5.3
numpy: 1.11.2
scipy: 0.18.1
OpenGL: 3.1.1a1
PIL.Image: 3.4.2
Platform: win32 64bit AMD64
This is GSAS-II revision 3977
The Bruker RAW ver. 3 reader was not able to read file C:\Users\ss626815\Documents\Measurements in samples\XRD\Natalya - BaWO4\BaWO4-Sample1.raw
Error message(s):
Bruker RAW ver. 3 read error:
Unhandled read exception: unpack requires a string argument of length 4
Traceback info:
Traceback (most recent call last):
File "C:\Users\ss626815\AppData\Local\Continuum\g2conda\GSASII\GSASIIdataGUI.py", line 806, in OnImportGeneric
blocknum=block,usedRanIdList=usedRanIdList,)
File "C:\Users\ss626815\AppData\Local\Continuum\g2conda\GSASII\imports\G2pwd_BrukerRAW.py", line 167, in Reader
y = np.array([max(1.,st.unpack('<f',fp.read(4))[0]) for i in range(nSteps)])
error: unpack requires a string argument of length 4
Dr. Sandra B. Schujman
Metrology Manager
[cid:image003.png at 01D50B24.52A4D500]
251 Fuller Rd., Albany, NY 12203
CESTM B230
Cell (518) 461-4020
Email: sschujman at sunypoly.edu
CONFIDENTIALITY NOTICE
The pages (including attachments) comprising this internet or facsimile transmission contain CONFIDENTIAL information. This information is intended for the sole and exclusive use by the individual entity named as the recipient hereof and any further disclosure or dissemination is prohibited. If you are not the intended recipient, you are hereby notified that any disclosure, copying, storage, distribution, or use of the contents of this transmission is strictly prohibited and may be unlawful. If you have received this transmission in error, please notify us immediately by telephone or return e-mail, delete it from your mail system, and destroy all copies in your possession.
Thank you.
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20190515/ecd09e41/attachment-0001.html>
Type: image/png
Desc: image003.png
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20190515/ecd09e41/attachment-0001.png>
More information about the GSAS-II
