[GSAS-II] GSAS-II keep crashes and giving error
Victor Zenou
zanov at post.bgu.ac.il
Fri Jul 12 07:04:23 CDT 2019
Dear Brian and Bob
I'm working on a file called "TiSc02_25C, which have 2 phases: anatase and
Pt sample holder. I still get errors:
loading from file: TiSc02_25C.bak117.gpx
GPX load successful. Last saved with GSAS-II revision 3270
save to file:
D:\2019k\collaborations\_Snejana\GSASII_MyWork\HTXRD\TiSc02_25\TiSc02_25C.gpx
project save successful
save to file:
Hessian Levenberg-Marquardt SVD refinement on 13 variables:
C:\Users\Victor\g2conda\GSASII\GSASIIstrMain.py:146:
VisibleDeprecationWarning: using a non-integer number instead of an integer
will result in an error in the future
covMatrix = result[1]*Rvals['GOF']**2
**** Refinement failed - singular matrix ****
****ERROR - Refinement failed
Traceback (most recent call last):
File "C:\Users\Victor\g2conda\GSASII\GSASIIdataGUI.py", line 4633, in
OnRefine
OK,Msg =
G2stMn.Refine(self.GSASprojectfile,dlg,refPlotUpdate=refPlotUpdate) #Msg
is Rvals dict if Ok=True
File "C:\Users\Victor\g2conda\GSASII\GSASIIstrMain.py", line 281, in
Refine
raise G2obj.G2Exception('****ERROR - Refinement failed')
GSASIIobj.G2Exception: '****ERROR - Refinement failed'
I used "analytical Jacbian" and got:
save to file:
Removing parameter: 1::AUiso:0
Read from
file:D:\2019k\collaborations\_Snejana\GSASII_MyWork\HTXRD\TiSc02_25\TiSc02_25C.bak125.gpx
Save to file
:D:\2019k\collaborations\_Snejana\GSASII_MyWork\HTXRD\TiSc02_25\TiSc02_25C.gpx
GPX file save successful
Refinement results are in file:
D:\2019k\collaborations\_Snejana\GSASII_MyWork\HTXRD\TiSc02_25\TiSc02_25C.lst
***** Refinement successful *****
GPX load successful. Last saved with GSAS-II revision 4057
I removed the parameter: "1::AUiso:0", meaning I don't refine it and got
off the contraint Uiso(Ti1)=Uiso(Sc1)
What see to be the problem?
Attached the gpx file.
Thanks, Victor
בתאריך יום א׳, 7 ביולי 2019 ב-22:59 מאת Von Dreele, Robert B. <
vondreele at anl.gov>:
> Victor,
> As Brian noted you have a singular matrix issue and the refinement thus
> fails. The Hessian refinement option is designed to immediately fail with
> the error you see. Alternatively, you can use the Jacobian method (see
> Controls). This will respond to the singular matrix by removing one of the
> offending parameters and then continuing the refinement. Look at the
> console; the listing will identify the bad parameter.
> Bob
> Sent from Mail <https://go.microsoft.com/fwlink/?LinkId=550986> for
> Windows 10
> *From: *Victor Zenou via GSAS-II <gsas-ii at aps.anl.gov>
> *Sent: *Sunday, July 7, 2019 2:27 PM
> *To: *gsas-ii-request at aps.anl.gov; gsas-ii at aps.anl.gov
> *Subject: *[GSAS-II] GSAS-II keep crashes and giving error
> Hi
> I using GSAS-II on windows 10 64 bit home (1809).
> Recently GSAS-II keeps crashing every few runs.
> Sometimes I get an error, without crashing:
> GSAS-II binary directory: C:\Users\Victor\g2conda\GSASII\bindist
> 6 values read from config file C:\Users\Victor\g2conda\GSASII\config.pyc
> Python module versions loaded:
> Python: 2.7.12
> wx: 3.0.0.0
> matplotlib: 1.5.3
> numpy: 1.11.2
> scipy: 0.18.1
> OpenGL: 3.1.1a1
> PIL.Image: 3.4.2
> Platform: win32 64bit AMD64
> This is GSAS-II revision 4054
> loading from file: TiSc02_25C.gpx
> GPX load successful. Last saved with GSAS-II revision 4054
> save to file: TiSc02_25C.gpx
> Hessian Levenberg-Marquardt SVD refinement on 8 variables:
> OnRefine
> OK,Msg =
> Refine
> Anyone have an idea what's wrong?
> Thanks, Victor
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20190712/ad191d4f/attachment-0001.html>
Desc: not available
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20190712/ad191d4f/attachment-0002.obj>
Desc: not available
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20190712/ad191d4f/attachment-0003.obj>
More information about the GSAS-II
