[GSAS-II] Pawley refinemet question
Sergey Ushakov svushakov at ucdavis.edu
Wed Apr 8 13:21:07 CDT 2020
Thank you, Brian, for clarifying this!
On Wed, Apr 8, 2020 at 11:14 AM Toby, Brian H. <toby at anl.gov> wrote:
> Hi Sergey,
>    Both LeBail and Pawley fits are not able to determine phase fractions
> because the scale factors are all arbitrary and thus the phase fractions
> cannot be refined. However, the reported mass/weight fractions are
> determined from the unrefined phase fractions and they are displayed even
> though meaningless.
> Brian
> On Apr 8, 2020, at 12:58 PM, Sergey Ushakov via GSAS-II <
> gsas-ii at aps.anl.gov> wrote:
> Greetings! I have a question maybe not specific to GSAS-II but more about
> Pawley vs Le Bail fitting of powder XRD data.
> I work on high temperature data from laser-heated solid spheroids which
> rotate in a gas flow in aerodynamic levitator.
> The data are collected in transmission geometry at 6-ID-D at APS.
> The rotation is not well controlled since it depends on the shape of each
> bead formed by melt solidification, i.e., on surface tension, volume change
> on melting, etc.
> So, sometimes data are very much powder-like and amenable to Rietveld
> refinement of the structure, but sometimes they are not, and in this case,
> I do Pawley fit for cell parameters.
> I used to do Le Bail fitting for that in GSAS-I, but I understand that it
> was replaced by Pawley refinement (although there is an option for Le Bail
> extraction of intensities?).
> To my surprise, Pawley fit in GSAS-II yield phase/weight fraction if one
> turns it on for refinement.
> I thought phase fraction could be correctly refined only from Rietveld?
> I would appreciate any comments on this!
> Sergey
> Sergey Ushakov PhD
> Staff Research Associate
> Peter A Rock Thermochemistry Laboratory and NEAT ORU
> Rm 4415, Chemistry Annex
> University of California, Davis
> Davis, CA 95616
> GSAS-II mailing list
> GSAS-II at aps.anl.gov
> https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
Sergey Ushakov PhD
Davis, CA 95616
phone (530) 902-8185
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20200408/878ce5e8/attachment-0001.html>
More information about the GSAS-II mailing list
