[GSAS-II] Tail clipping in simulated patterns
Joress, Howie (Fed)
howie.joress at nist.gov
Thu Apr 23 10:01:43 CDT 2020
I am new to GSAS-II. I am trying to use it to create a set of simulated diffraction patterns using the standard simulation method. I am interested in looking at simulations of small peaks next to large peaks.
I am having an in the way it is modeling the peak tails. It looks like it is clipping them, leading to some artifacts around the background. I think I need to widen the range that the model for each peak is covering. Is there anyway to remove these artifacts?
Howie Joress
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20200423/ac524989/attachment-0001.html>
Type: image/png
Desc: forfan.png
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20200423/ac524989/attachment-0001.png>
Desc: test2.gpx
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20200423/ac524989/attachment-0001.obj>
More information about the GSAS-II
