[GSAS-II] Adding soft restraints on angles
Joel Reid Joel.Reid at lightsource.ca
Tue May 12 11:50:57 CDT 2020
Hello Brian and Bob,
Is there a way to loosen the criteria for finding potential angles for soft constraints?
In a couple of structures, I've had to use a few different restraint values to find all the appropriate distance restraints, but it is doable. But no matter what restraint value I try for the angles, it won't find the angles.
I'm trying to add bond angle restraints to AlO6 octahedra, where the trial structure (from FOX) has a range of Al-O distances (1.6 to 2.4 A)...
Thank you for your time, I really appreciate it.
Sincerely,
Joel
Joel Reid, Ph.D.
Industrial Staff Scientist
Canadian Light Source
44 Innovation Boulevard
Saskatoon, SK
S7N 2V3
(306) 657-3854
www.lightsource.ca<http://www.lightsource.ca/>
http://www.usask.ca/maps/map-nav/campus_maps/uofsmap.pdf
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20200512/0ca1e44d/attachment.html>
More information about the GSAS-II mailing list
