[GSAS-II] fwhm and amplitude of peaks
Toby, Brian H. toby at anl.gov
Thu Jul 16 08:39:02 CDT 2020
Howie,
Let me be careful here in distinguishing between peaks and reflections, where peaks can contain one or more reflection (possibly from multiple phases) and only have a position, intensity and gaussian & cauchy widths and are most important for unindexed patterns, while reflections are tabulated by hkl, with lots of information including Gaussian & Cauchy widths, see https://gsas-ii.readthedocs.io/en/latest/GSASIIobj.html#powderrefl-table. Look at the old manual for GSAS to see how sigma and gamma are defined. I don’t think that has made it to the GSAS-II docs.
There are commands and API commands to export peak lists, but I think you want a reflection list, which can be exported with Export/"Powder Data…" From the API, you might be able to use G2PwdrData.Export() (see https://gsas-ii.readthedocs.io/en/latest/GSASIIscriptable.html#GSASIIscriptable.G2PwdrData.Export) to get what you want (you might have to write your own exporter, using the supplied ones as a template.) The reflection list(s) (by phase) are contained in  GSASIIscriptable.G2PwdrData.data[‘Reflection Lists’]<https://gsas-ii.readthedocs.io/en/latest/GSASIIscriptable.html#GSASIIscriptable.G2PwdrData.Export>.
Brian
On Jul 15, 2020, at 7:56 PM, Joress, Howie (Fed) via GSAS-II <gsas-ii at aps.anl.gov<mailto:gsas-ii at aps.anl.gov>> wrote:
I will add is there a way to do this using the python API?
From: GSAS-II <gsas-ii-bounces at aps.anl.gov<mailto:gsas-ii-bounces at aps.anl.gov>> on behalf of Joress, Howie (Fed) via GSAS-II <gsas-ii at aps.anl.gov<mailto:gsas-ii at aps.anl.gov>>
Sent: Wednesday, July 15, 2020 8:54 PM
To: gsas-ii at aps.anl.gov<mailto:gsas-ii at aps.anl.gov> <gsas-ii at aps.anl.gov<mailto:gsas-ii at aps.anl.gov>>
Subject: [GSAS-II] fwhm and amplitude of peaks
Is there a straightforward way to export the amplitude and fwhm of each peak in a pattern.  In my case this is a simulated pattern.
Howie
GSAS-II mailing list
GSAS-II at aps.anl.gov<mailto:GSAS-II at aps.anl.gov>
https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20200716/14536b98/attachment-0001.html>
More information about the GSAS-II mailing list
