[GSAS-II] Defining a constraint equation
Toby, Brian H.
toby at anl.gov
Thu Jul 16 18:05:45 CDT 2020
Yes. See step #3 in the Garnet tutorial (https://subversion.xray.aps.anl.gov/pyGSAS/Tutorials/CWNeutron/Neutron%20CW%20Powder%20Data.htm)
You can set a single mult values as you wish as you enter the value (the other must be 1). To change the sum, you must edit the constraint after it is created.
More complex types of formulae can be created as chemistry constraints.
Brian
On Jul 16, 2020, at 4:30 PM, Marcos Imer via GSAS-II <gsas-ii at aps.anl.gov<mailto:gsas-ii at aps.anl.gov>> wrote:
Dear all,
I would like to define the following constraint equation in GSAS2:
Atomic_fracc(Atom1)*mult + Atomic_fracc(Atom2)*mult = Number
Is there any way to do this?
Marcos
GSAS-II mailing list
GSAS-II at aps.anl.gov<mailto:GSAS-II at aps.anl.gov>
https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20200716/b4d65001/attachment.html>
More information about the GSAS-II
