[GSAS-II] Minor GUI issue with excluded regions
Ivo Alxneit
ivo.alxneit at psi.ch
Mon Feb 8 07:22:56 CST 2021
Dear all
running GSASII on linux I noted that excluded regions are still plotted.
In the Delta(I)/sigma(I) plot and in the Error Analysis plot. this
affects the auto scaling of the y-axis (values in the excluded region
are much higher that in the interesting part of the data). I'd suggest
that excluded data ranges are masked. Right now it looks as if I_calc is
set to zero there and the full data range is used for plotting.
My configuration:
8 values read from config file
/home/alxneit/share/miniconda3/envs/gsas/GSASII/config.py
09:29:11: Debug: Adding duplicate image handler for 'Windows bitmap file'
Python module versions loaded:
Python: 3.7.9 from /home/alxneit/share/miniconda3/envs/gsas/bin/python
wx: 4.0.4
matplotlib: 3.3.2 version is too new and could cause problems
numpy: 1.19.2
scipy: 1.5.2
OpenGL: 3.1.1a1
Image: 8.0.1 (PIL or Pillow)
Platform: linux 64bit x86_64
Max threads:2
Latest GSAS-II revision (from .py files): 4666 (SVN version 4666)
Gruss and thanks
Dr. Ivo Alxneit
Applied Catalysis and Spectroscopy Group
Bioenergy and Catalysis Laboratory phone: +41 56 310 4092
Paul Scherrer Institute fax: +41 56 310 2688
CH-5232 Villigen gnupg key: 0x515E30C7
Switzerland
https://www.psi.ch/acs/
Desc: OpenPGP digital signature
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20210208/6ed0c978/attachment.sig>
More information about the GSAS-II
