[GSAS-II] How to deal with parameters from Data-Tab in sequential refinements?
Ivo Alxneit
ivo.alxneit at psi.ch
Mon Mar 8 09:39:11 CST 2021
Dear all
I am performing sequential refinements. I can include HAP parameters
such as e.g. 'size' in a refinement and later just un-tick the parameter
to exclude it from the next refinement BUT keeping the values of 'size'
from the previous refinement. I.e. 'size' is now fixed but each
histogram might use a different value. I can also manually change the
value of the parameter at some histograms if required (correct outliers).
How can I do the same with parameters contained in the 'Atoms'-Tab such
as e.g. the fractional coordinates of some atoms? I assume this is
connected to the 'Sequential Refinement Options' part in the 'Data'-Tab
but I am at a loss here. Also, how can I manually edit a specific value
for a given histogram like I did above with 'size'?
Thanks for any help
Ivo
My config (Linux)
alxneit at triolite:~$ gsas
GSAS-II binary directory:
/home/alxneit/share/miniconda3/envs/gsas/GSASII/bindist
8 values read from config file
/home/alxneit/share/miniconda3/envs/gsas/GSASII/config.py
16:32:16: Debug: Adding duplicate image handler for 'Windows bitmap file'
Python module versions loaded:
Python: 3.7.9 from /home/alxneit/share/miniconda3/envs/gsas/bin/python
wx: 4.0.4
matplotlib: 3.3.2
numpy: 1.19.2
scipy: 1.5.2
OpenGL: 3.1.1a1
Image: 8.0.1 (PIL or Pillow)
Platform: linux 64bit x86_64
Max threads:2
Latest GSAS-II revision (from .py files): 4826 (SVN version 4826)
Dr. Ivo Alxneit
Applied Catalysis and Spectroscopy Group
Bioenergy and Catalysis Laboratory phone: +41 56 310 4092
Paul Scherrer Institute fax: +41 56 310 2688
CH-5232 Villigen gnupg key: 0x515E30C7
Switzerland
https://www.psi.ch/acs/
Desc: OpenPGP digital signature
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20210308/daa8556d/attachment.sig>
More information about the GSAS-II
