[GSAS-II] Image controls: "Penetration" and "Apply detector absorption"
Beatriz Diaz bdiazmoreno at gmail.com
Fri Oct 15 12:59:54 CDT 2021
Good afternoon!
Please, could you give a bit more detail about the parameters "Penetration"
and "Apply detector absorption" within the image controls? There seems to
be some overlap between them, if Penetration refers to the detector? I have
checked the tutorials and these parameters remain unused (unchecked). Could
I infer that their influence in the results is very subtle? Default for
detector absorption is 0.5. Is this value used, even when unchecked? I'm
using a PerkinElmer area detector, generally at 30 or 60keV energies and
normal incidence.
Many thanks! Beatriz
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20211015/2bc4bb95/attachment.html>
More information about the GSAS-II mailing list
