[GSAS-II] [BUG] Unable to start application with python versions 3.10 or higher
Bartłomiej Gędziorowski
b.gedzior at gmail.com
Fri Feb 4 03:10:15 CST 2022
Hello everybody,
I use GSAS-II on Archlinux and I'm the maintainer of the
https://aur.archlinux.org/packages/gsas2-svn package. In the current
sources, there is a bug in the file GSASIIdataGUI.py at the line 617:
|elif platform.python_version()[:3] not in ['2.7','3.6','3.7','3.8','3.9']:|
I currently use python 3.10.2. This version is not only missing on the
list, but also when added, the 'platform.python_version()[:3]' return
3.1. I was able to make a hotfix for my self by changing the line as
follows:
|elif platform.python_version()[:4] not in
['2.7','3.6','3.7','3.8','3.9','3.10']:|
I don't know if it's a valid solution (I'm, not a python developer) but
maybe You will find better one ;)
Best regards,
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20220204/b6db047e/attachment.html>
More information about the GSAS-II
