[GSAS-II] Requesting guidance on reading a CIF file via GSAS-II
Leopoldo Suescun leopoldo at fq.edu.uy
Thu Oct 3 20:29:15 CDT 2024
Dear Abishek Rawat,
Cu+3 is not a frequent oxidation state of Cu therefore the atomic
scattering factors are not available in most refinement programs.
I suggest you make all atoms neutral Ag, Cu and O. You will get the same
response without the error.
You can do this in the input CIF file or in the atoms tab in GSAS II.
Otherwise you will need to find the atomic scattering factor parameters for
Cu+3 and input them in GSAS II to obtain an almost non distinguishable
result.
Best of luck.
Leo
El jue, 3 de oct de 2024, 20:13, Rawat, Abhishek via GSAS-II <
gsas-ii at aps.anl.gov> escribió:
> Dear Concerned person, Hope this email finds you well. I am using GSAS-II
> to refine my XRD data. I have an unusual composition which has copper atoms
> in a +3 oxidation state. GSAS gives an error message when uploading the CIF
> because of the
> ZjQcmQRYFpfptBannerStart
> This Message Is From an External Sender
> This message came from outside your organization.
> ZjQcmQRYFpfptBannerEnd
> I am using GSAS-II to refine my XRD data. I have an unusual composition
> which has copper atoms in a +3 oxidation state. GSAS gives an error message
> when uploading the CIF because of the Cu +3 state. Is there any solution to
> this issue?
> The composition is AgCuO2; copper has been reported in the +3 state by the
> researchers and in the submitted PXRD database files. How to sort this
> issue? Your guidance would be much appreciated.
> Thanks and regards
> Abhishek Rawat
> Graduate Teaching Assistant
> Chemistry and Biochemistry- UTA
> GSAS-II mailing list
> GSAS-II at aps.anl.gov
> https://urldefense.us/v3/__https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii__;!!G_uCfscf7eWS!Z3SvZ_u2rPzWis6dwBZVIKJv9tcGc6PFPkq6EFZaN42o1WYuR1ixY-zu-soKobVSas-JWEfPdZdfTEAoI1xevqA$
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20241003/0c5abd85/attachment-0001.html>
More information about the GSAS-II mailing list
