[GSAS-II] Import powder data in Q
Toby, Brian H.
toby at anl.gov
Thu Feb 13 19:49:36 CST 2025
Hi Samantha,
There is only one format that can be used to read data that is recorded in steps of Q and that implemented in the imports\G2pwd_xye.py importer. If the file extension is .qchi, then there should be a header with Q and then the wavelength separated by a space. Alternately if extension .qye is used, then the header line should be #Q <wave> (or ‘Q … or !Q …). Subsequent lines will contain Q, intensity and optionally sigma(intensity), one set of 2 or 3 values per line. Values can be separated by spaces, a comma or a semicolon.
The values are converted from Q to 2theta and thus a wavelength is required.
Brian
From: GSAS-II <gsas-ii-bounces at aps.anl.gov> on behalf of Clarke, Samantha M. via GSAS-II <gsas-ii at aps.anl.gov>
Date: Thursday, February 13, 2025 at 6:43 PM
To: gsas-ii at aps.anl.gov <gsas-ii at aps.anl.gov>
Subject: [GSAS-II] Import powder data in Q
Hello! In another program, I’ve exported my powder diffraction data in Q rather than 2-theta. It is an xy file where the first column is Q and the second is I. I’m wondering if anyone knows how to import this data into GSAS-II. It
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Hello!
In another program, I’ve exported my powder diffraction data in Q rather than 2-theta. It is an xy file where the first column is Q and the second is I. I’m wondering if anyone knows how to import this data into GSAS-II. It seems like by default, the data is imported as 2-theta.
Sam
Samantha M. Clarke, Ph.D.
Staff Scientist
Lawrence Livermore National Laboratory
Physical and Life Sciences Directorate
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20250214/52efc87a/attachment-0001.html>
More information about the GSAS-II
