[GSAS-II] GSAS-II Rigid Body Refinement with Partial Disorder in a CF3COO Group
Dayane Vieira Nascimento dos Santos
dayane.santos at wayne.edu
Fri Jun 19 13:17:30 CDT 2026
I am trying to refine a CF3COO group as a rigid body in a crystal with space group P-1. The atoms in the group occupy sites with 1 symmetry. The CF3 moiety is disordered over two positions with a 70:30 occupancy ratio.
When I define the entire CF3COO group as a rigid body and keep the occupancy fixed, the refinement quality deteriorates significantly: the Rw increases from about 5% to 20%, and the fit becomes much worse. However, if I allow the occupancy to refine, the refinement converges well and the fit remains good (Rw ≈ 5%). The problem is that the resulting structure assigns fractional occupancies (0.5 or lower) not only to the disordered CF₃ moiety but also to the COO group, which was not disordered in the original model.
My question is: how can I refine a rigid body in which only part of the group has fractional occupancy? More specifically, is there a way in GSAS-II to model a rigid body where the CF3 atoms are disordered, but the COO atoms remain fully occupied?
I am a little puzzled because GSAS-I/EXPGUI handled this situation without any apparent difficulty, so I suspect there must be a way to do it in GSAS-II as well.
Any suggestions or guidance would be greatly appreciated.
Thank you,
Dayane V. N. Dos Santos
Graduate Teaching Assistant
Department of Chemistry
Wayne State University
Detroit, MI 48202
Email: dayane.santos at wayne.edu
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20260619/391eda7c/attachment.html>
More information about the GSAS-II
