[GSAS-II] Bug Report GSAS_II
Dilini Kaushalya Wijepala hp5540 at wayne.edu
Fri Aug 28 14:25:26 CDT 2026
My name is Dilini Wijepala, and I am a fourth-year graduate student who uses GSAS-II. I would like to report a bug that I encountered while using the software.
I encountered a problem while trying to refine the position (pos), intensity (int), and sigma (sig) of peaks added under the Background tab. The data used in this refinement were NOMAD neutron total scattering data. After adding reasonable initial guesses for the position, intensity, and sigma, the peaks in the background showed reasonable shapes. However, these parameters could not be refined. Each time I performed a refinement, the parameters were dropped.
I have attached a Word document containing the relevant information and details of the refinement.
Please note that this refinement was performed using the updated version of GSAS-II (5839). I also tested the same refinement using an older version (5660), and everything worked as expected. However, after updating that older version to 5799, the refinement stopped working.
I would greatly appreciate your assistance in investigating this issue.
Thank you very much for your time and help.
Best regards,
Dilini Wijepala
Thanks & regards.
Dilini Wijepala
Graduate Teaching Assistant
Department of Chemistry
Wayne State University
Detroit, Michigan 48202
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20260828/a358102f/attachment-0001.html>
Desc: YNTO_30p_Bank_2.gpx
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20260828/a358102f/attachment-0001.obj>
Type: application/vnd.openxmlformats-officedocument.wordprocessingml.document
Desc: Info.docx
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20260828/a358102f/attachment-0001.docx>
More information about the GSAS-II mailing list
