[GSAS-II] Errors during powder pattern import
Bernd Maier bernd.maier at lmu.de
Fri Feb 14 06:34:51 CST 2014
Hello,
I want to report the following errors during data import using this system
setup:
GSAS-II binary directory:  /opt/GSAS2/bin
Python module versions loaded:
python:      2.7.6
wxpython:    2.8.12.1
matplotlib:  1.3.1
numpy:       1.8.0
scipy:       0.13.3
OpenGL:      3.0.2a5
This is GSAS-II version:      0.2.0  revision 1219
On loading a XY dataset without specifying an instrument resolution file but
choosing defaults for lab Cu X-rays, the following error occurs:
/opt/GSAS2/imports/G2pwd_xye.py:23: RuntimeWarning: invalid value encountered
in arcsin
  npasind = lambda x: 180.*np.arcsin(x)/np.pi
Traceback (most recent call last):
  File "/opt/GSAS2/GSASII.py", line 1172, in OnImportPowder
    Iparm1,Iparm2 = self.GetPowderIparm(rd, Iparm, lastIparmfile, lastdatafile)
  File "/opt/GSAS2/GSASII.py", line 1139, in GetPowderIparm
    return SetPowderInstParms(rd.defaultIparms[res],rd)
  File "/opt/GSAS2/GSASII.py", line 930, in SetPowderInstParms
    wave1 = wl[0]
TypeError: 'float' object has no attribute '__getitem__'
If I use an instrument resolution file, the pattern loads, but is not shown in
the graph plot. The following error is given:
/usr/lib/python2.7/site-packages/matplotlib/lines.py:503: RuntimeWarning:
invalid value encountered in greater_equal
  return np.alltrue(x[1:] - x[0:-1] >= 0)
When I was still using ubuntu 12.04 it was working, now I'm on archlinux which
has newer packages. I guess this might be the problem. This is by the way true
for wxpython, since the dialogs work only properly for version 2.8, not for
3.0.
Best wishes,
Bernd
Dr. Bernd Maier
Ludwig-Maximilians Universität München
Department für Geo- und Umweltwissenschaften
Sektion Kristallographie
Theresienstraße 41
D-80333 München
Phone: +49 (0)89 2180 4340
Fax: +49 (0)89 2180 4334
E-mail: bernd.maier at lmu.de
More information about the GSAS-II mailing list
