[GSAS-II] Simulated Data Sets
Toby, Brian H. toby at anl.gov
Mon Sep 8 14:27:42 CDT 2014
Caleb,
  You are correct that this needs a tutorial — someday! The process of simulating a pattern is similar to setting up a refinement. However, for a dataset, on the import/powder data menu you will see a simulate option.
   You probably will want to keep the histogram instrument and sample parameters unchanged from their defaults, but will want to change the ones on the Phase/Data tab.
  There is no powpref in GSAS-II. Use the Calculate/Refine option to compute the simulated pattern.
Brian
On Sep 8, 2014, at 1:56 PM, Caleb Hustedt <chustedt at gmail.com<mailto:chustedt at gmail.com>> wrote:
I am new to both GSAS and GSAS-II. I am trying to simulate an x-ray dataset for textured Magnesium. I know how to create a simulated dataset in GSAS using POWPREF and GENLES. However, I do not know how to simulate a dataset in GSAS-II or where the corresponding options are for POWPREF or GENLES. How do you simulate a diffraction pattern using GSAS-II? Is there any good documentation that I missing? Any help would be appreciated.
Thank you,
Caleb Hustedt
Caleb Hustedt
Ph.D. Candidate
Department of Materials Science and Engineering
Johns Hopkins University
GSAS-II mailing list
GSAS-II at mailman.aps.anl.gov<mailto:GSAS-II at mailman.aps.anl.gov>
https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
Brian H. Toby, Ph.D.                            office: 630-252-5488
Senior Physicist/Section Head for Scientific Software
Advanced Photon Source
9700 S. Cass Ave, Bldg. 401/B4192            work cell: 630-327-8426
Argonne National Laboratory
Argonne, IL 60439-4856         e-mail: brian dot toby at anl dot gov
"We will restore science to its rightful place, and wield technology's wonders... We will harness the sun and the winds and the soil to fuel our cars and run our factories...  All this we can do. All this we will do."
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20140908/3594b9c9/attachment.html>
More information about the GSAS-II mailing list
