[GSAS-II] Simulated Data Sets
Robert Von Dreele
vondreele at aps.anl.gov
Mon Sep 8 16:34:43 CDT 2014
Caleb,
I'd only add that GSAS-II makes simulated patterns the same way as GSAS
in that you need to choose a scale factor (see Sample Parameters) and
suitable background (see Background). A bit of trial & error might be
needed to get something sensible. NB: do set the number of cycles=0;
otherwise GSAS-II will refine to your simulation!
Bob
On 9/8/2014 2:27 PM, Toby, Brian H. wrote:
> Caleb,
> You are correct that this needs a tutorial — someday! The process of
> simulating a pattern is similar to setting up a refinement. However,
> for a dataset, on the import/powder data menu you will see a simulate
> option.
> You probably will want to keep the histogram instrument and sample
> parameters unchanged from their defaults, but will want to change the
> ones on the Phase/Data tab.
> There is no powpref in GSAS-II. Use the Calculate/Refine option to
> compute the simulated pattern.
> Brian
> On Sep 8, 2014, at 1:56 PM, Caleb Hustedt <chustedt at gmail.com
> <mailto:chustedt at gmail.com>> wrote:
>> Hi,
>> I am new to both GSAS and GSAS-II. I am trying to simulate an x-ray
>> dataset for textured Magnesium. I know how to create a simulated
>> dataset in GSAS using POWPREF and GENLES. However, I do not know how
>> to simulate a dataset in GSAS-II or where the corresponding options
>> are for POWPREF or GENLES. How do you simulate a diffraction pattern
>> using GSAS-II? Is there any good documentation that I missing? Any
>> help would be appreciated.
>> Thank you,
>> Caleb Hustedt
>> Caleb Hustedt
>> Ph.D. Candidate
>> Department of Materials Science and Engineering
>> Johns Hopkins University
>> GSAS-II mailing list
>> GSAS-II at mailman.aps.anl.gov <mailto:GSAS-II at mailman.aps.anl.gov>
>> https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
> Brian H. Toby, Ph.D. office: 630-252-5488
> Senior Physicist/Section Head for Scientific Software
> Advanced Photon Source
> 9700 S. Cass Ave, Bldg. 401/B4192 work cell: 630-327-8426
> Argonne National Laboratory
> Argonne, IL 60439-4856 e-mail: brian dot toby at anl dot gov
> "We will restore science to its rightful place, and wield technology's
> wonders... We will harness the sun and the winds and the soil to fuel
> our cars and run our factories... All this we can do. All this we
> will do."
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20140908/d0f2f374/attachment.html>
More information about the GSAS-II
