[GSAS-II] Update command fails after Mac "single step installer"
Toby, Brian H. toby at anl.gov
Tue Jun 21 16:44:46 CDT 2016
Yes, this is a bug! I have fixed it in the latest version of GSAS-II (#2337).
Since you need to get this update to fix updating, you need to use the command line (in terminal) to download it. (Yes, you could just reinstall).
1) find the directory where you installed the g2conda distribution (usually in your home directory) with finder
2) open a terminal window (Applications/Utilities)
3) type “cd " (note the space at the end) — do not press enter
4) drag the g2conda to the terminal window (a string like /Users/<yourname>/g2conda will appear)
5) press enter
6) type “bin/python GSASII/bootstrap.py” and press enter
7) press enter (or enter a proxy address, as before) to upgrade.
[cid:FBDF214E-86BD-4D21-ABAD-E6C8833C7345 at aps.anl.gov]
On Jun 21, 2016, at 11:50 AM, gsas-ii-bounces at aps.anl.gov<mailto:gsas-ii-bounces at aps.anl.gov> wrote:
The attached message has been automatically discarded.
From: Cara Vennari <cvennari at ucsc.edu<mailto:cvennari at ucsc.edu>>
Subject: GSAS-2 Updates
Date: June 21, 2016 at 11:50:29 AM CDT
To: <gsas-ii at mailman.aps.anl.gov<mailto:gsas-ii at mailman.aps.anl.gov>>
Hi there,
I downloaded GSAS-2 this morning on Mac (OS X El Capitan) using the "single step installer", and didn't recieve any errors.  I then tried to check for updates (which I realize shouldn't exist yet because I probably have the most recent version) and got an error which may be interesting to you? See attached photo.
Cara
<Screen Shot 2016-06-21 at 10.44.10 AM.png>
[cid:826CDB0D-088F-4FF7-B0B6-62BC24DCE377 at aps.anl.gov]
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20160621/4f4e8410/attachment-0001.html>
Type: image/png
Desc: PastedGraphic-1.png
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20160621/4f4e8410/attachment-0002.png>
Name: Screen Shot 2016-06-21 at 10.44.10 AM.png
Type: image/png
Desc: Screen Shot 2016-06-21 at 10.44.10 AM.png
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20160621/4f4e8410/attachment-0003.png>
More information about the GSAS-II mailing list
