[GSAS-II] Can Parameters be restricted?
William Boyer
WBoyer at protoxrd.com
Mon Sep 12 13:47:32 CDT 2016
If your data is noisy, limits can also help keep the parameters from getting stuck in physically impossible local minima. For example, I might set a minimum FWHM to a little less than the narrowest peak my instrument can produce, then a few random points that happen to be above average cannot be mistaken for a peak.
Best regards,
William Boyer
From: gsas-ii-bounces at aps.anl.gov [mailto:gsas-ii-bounces at aps.anl.gov] On Behalf Of Toby, Brian H.
Sent: Monday, September 12, 2016 5:42 AM
To: Ivo Alxneit <ivo.alxneit at psi.ch>
Cc: Von Dreele, Robert B. <vondreele at aps.anl.gov>; gsas-ii at mailman.aps.anl.gov
Subject: Re: [GSAS-II] Can Parameters be restricted?
No.
To be honest I am not sure why one would want to do this. When a parameter refines "out of range” it tells you something about your data or model. With a restraint, you would never know that for example, a Uiso value is refining negative by > 2 sigma or a occupancy is >>1. It makes sense to me to define a model so that the sum of occupancies is fixed — a well defined assumption. Defining a range for a parameter scares me as I could never know that my model is highly flawed is some way.
Brian
On Sep 12, 2016, at 10:27 AM, Ivo Alxneit <ivo.alxneit at psi.ch <mailto:ivo.alxneit at psi.ch> > wrote:
Dear all
is there a way to restrict fitted parameters to a certain range? For
example restrict site occupancies to positive numbers or to a range such
as 0.9-1.0?
thanks for any help
Dr. Ivo Alxneit
Catalysis for Energy Group
Bioenergy and Catalysis Laboratory phone: +41 56 310 4092
Paul Scherrer Institute fax: +41 56 310 2688
CH-5232 Villigen gnupg key: 0x515E30C7
Switzerland
https://www.psi.ch/ceg/catalysis-for-energy-group/
GSAS-II mailing list
GSAS-II at mailman.aps.anl.gov <mailto:GSAS-II at mailman.aps.anl.gov>
https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
Brian H. Toby, Ph.D. office: 630-252-5488
Advanced Photon Source Chief Computational Scientist
Senior Physicist/Computational X-ray Science Group Leader
9700 S. Cass Ave, Bldg. 401/B4192 cell: 630-327-8426
Argonne National Laboratory
Argonne, IL 60439-4856 e-mail: brian dot toby at anl dot gov
"We will restore science to its rightful place, and wield technology's wonders... We will harness the sun and the winds and the soil to fuel our cars and run our factories... All this we can do. All this we will do."
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20160912/6eeecfc1/attachment.html>
More information about the GSAS-II
