[GSAS-II] Can Parameters be restricted?
Andrzej Falenty
afalent at uni-goettingen.de
Tue Sep 13 04:10:05 CDT 2016
Dear Brian,
if I may to drop the comment. The enquiry is not entirely without merit.
It is not infrequent that one combines information from many sources to
build a model and constrains help to fix deficiency of a single method.
I guess that one case where a hard limit could be useful is a case of
vacancies in non-stoichiometric compounds. As you say it is easy to
constrain a site shared by multiple elements if they add up to 1. Yet,
there has been always a problem, also for GSAS I, to deal with a sum of
vacancy + element on a site. From this what I observed the refinement
was trying to compensate vacancies with artificiality increased thermal
displacement parameters if the data at higher 2-Theta were not "perfect"
(actually only a case of good TOF with neutrons or an exceptional
quality X-ray diffraction). If I know that the occupancy cannot be
larger than e.g. 1 for a site from other sources (e.g. spectroscopy or
other x-ray neutron diffraction experiments) then it should be possible
to set a hard limit on the site. Of course such decision must be well
substantiated. Otherwise one risks producing some rubbish results...
Best wishes
Andrzej
Am 12.09.2016 um 11:42 schrieb Toby, Brian H.:
> No.
> To be honest I am not sure why one would want to do this. When a
> parameter refines "out of range” it tells you something about your
> data or model. With a restraint, you would never know that for
> example, a Uiso value is refining negative by > 2 sigma or a occupancy
> is >>1. It makes sense to me to define a model so that the sum of
> occupancies is fixed — a well defined assumption. Defining a range for
> a parameter scares me as I could never know that my model is highly
> flawed is some way.
> Brian
>> On Sep 12, 2016, at 10:27 AM, Ivo Alxneit <ivo.alxneit at psi.ch
>> <mailto:ivo.alxneit at psi.ch>> wrote:
>> Dear all
>> is there a way to restrict fitted parameters to a certain range? For
>> example restrict site occupancies to positive numbers or to a range such
>> as 0.9-1.0?
>> thanks for any help
>> Dr. Ivo Alxneit
>> Catalysis for Energy Group
>> Bioenergy and Catalysis Laboratory phone: +41 56 310 4092
>> Paul Scherrer Institute fax: +41 56 310 2688
>> CH-5232 Villigen gnupg key: 0x515E30C7
>> Switzerland
>> https://www.psi.ch/ceg/catalysis-for-energy-group/
>> GSAS-II mailing list
>> GSAS-II at mailman.aps.anl.gov
>> https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
> Brian H. Toby, Ph.D. office: 630-252-5488
> Advanced Photon Source Chief Computational Scientist
> Senior Physicist/Computational X-ray Science Group Leader
> 9700 S. Cass Ave, Bldg. 401/B4192 cell: 630-327-8426
> Argonne National Laboratory
> Argonne, IL 60439-4856 e-mail: brian dot toby at anl dot gov
> "We will restore science to its rightful place, and wield technology's
> wonders... We will harness the sun and the winds and the soil to fuel
> our cars and run our factories... All this we can do. All this we
> will do."
Dr. Andrzej Falenty <afalent at uni-goettingen.de>
Abt. Kristallographie
GZG, Georg-August-Universität
Goldschmidtstraße 1
D-37077 Göttingen
Tel. 0049 551 3912546
http://kristall.uni-mki.gwdg.de/
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20160913/b41aaad1/attachment.html>
More information about the GSAS-II
