[GSAS-II] HDF5 reader
Ivo Alxneit
ivo.alxneit at psi.ch
Tue Oct 25 02:58:43 CDT 2016
Hi Davide
this just tells you that you have not installed h5py (assuming you use
the anaconda distribution you could 'conda install h5py'). As long as
you do not need to read/write HDF data, you are fine.
gruss ivo
On 25.10.2016 09:25, davide levy wrote:
> Hi
> starting GSAS-II I have got this message
> HDF5 Reader skipped because h5py library is not installed
> is it a problem? How can I load h5py library?
> Best
> Davide
> GSAS-II mailing list
> GSAS-II at mailman.aps.anl.gov
> https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
Dr. Ivo Alxneit
Catalysis for Energy Group
Bioenergy and Catalysis Laboratory phone: +41 56 310 4092
Paul Scherrer Institute fax: +41 56 310 2688
CH-5232 Villigen gnupg key: 0x515E30C7
Switzerland
https://www.psi.ch/ceg/catalysis-for-energy-group/
Desc: OpenPGP digital signature
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20161025/9e511c13/attachment.sig>
More information about the GSAS-II
