[GSAS-II] HDF5 reader
Toby, Brian H.
toby at anl.gov
Tue Oct 25 12:27:31 CDT 2016
This one is my error — at least with the new single-download installer based on miniconda. I did not include one of the two packages needed to access the hdf5 reader.
Assuming you have used anaconda/miniconda this the command
conda install h5py hdf5
should fix this. If you get an error that conda is an unknown command, you will need to use a full path:
~/g2conda/bin/conda install h5py hdf5
or
\Users\me\g2conda\conda install h5py hdf5
I hope to get this fixed soon fro fresh installs.
Brian
On Oct 25, 2016, at 2:25 AM, davide levy <davide.levy69 at gmail.com<mailto:davide.levy69 at gmail.com>> wrote:
Hi
starting GSAS-II I have got this message
HDF5 Reader skipped because h5py library is not installed
is it a problem? How can I load h5py library?
Best
Davide
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20161025/68f3a597/attachment.html>
More information about the GSAS-II
