[GSAS-II] I can not export CIF-full in GSAS-II (Edward Ebner Avila Sosa)
Yang Yushi yangyushi1992 at icloud.com
Fri Nov 4 02:31:05 CDT 2016
> Today's Topics:
>   1. I can not export CIF-full in GSAS-II (Edward Ebner Avila Sosa)
> Message: 1
> Date: Thu, 3 Nov 2016 10:31:29 -0430 (VET)
> From: Edward Ebner Avila Sosa <eavila at ivic.gob.ve>
> To: gsas-ii at aps.anl.gov
> Subject: [GSAS-II] I can not export CIF-full in GSAS-II
> Message-ID:
> 	<1848592571.140252.1478185289340.JavaMail.zimbra at ivic.gob.ve>
> Content-Type: text/plain; charset="utf-8"
> Hi everyone,
> I have a problem with GSAS-II program for export full CIF. This generate me the following errors:
> Writing CIF output to file LaFeAlO3_3.cif...
> Traceback (most recent call last):
> File "C:\GSASII\GSASII.py", line 133, in MenuBinding
> log.InvokeMenuCommand(event.GetId(),self,event)
> File "C:\GSASII\GSASIIlog.py", line 458, in InvokeMenuCommand
> handler(event)
> File "C:\GSASII\exports\G2export_CIF.py", line 2001, in Exporter
> self._Exporter(event=event)
> File "C:\GSASII\exports\G2export_CIF.py", line 1819, in _Exporter
> str(self.shortauthorname) + "|" + instnam)
> File "C:\GSASII\exports\G2export_CIF.py", line 71, in WriteCIFitem
> self.fp.write('; '+value+'\n')
> UnicodeEncodeError: 'ascii' codec can't encode character u'\xed' in position 69: ordinal not in range(128)
Is there some non-ascii characters in your "Instrument names”? I can re-produce similar error message by insert character í to the instrument names.
> The GSAS-II version that I am using is 2511. Nevertheless, when I run the program and it ends, wirtes the lines down.
> C:\Users\Edward\Documents\Colaboraciones\Raquel del Toro\Refinamiento_Perovskita\MyWorks\RAQ-61A\Rietveld_PDF2-3\LaFeAlO3_3.gpx
> project save successful
> Hessian refinement on 16 variables:
> 26 derivative time 0.0020
> matrix modification needed; lambda now 1.0e-02
> matrix modification needed; lambda now 1.0e-01
> Cycle: 0, Time: 0.36s, Chi**2: 6881.7, Lambda: 0.01, Delta: -4.69e-05
> converged
> 26 derivative time 0.0040
> Read from file: C:\Users\Edward\Documents\Colaboraciones\Raquel del Toro\Refinamiento_Perovskita\MyWorks\RAQ-61A\Rietveld_PDF2-3\LaFeAlO3_3.bak86.gpx
> Save to file : C:\Users\Edward\Documents\Colaboraciones\Raquel del Toro\Refinamiento_Perovskita\MyWorks\RAQ-61A\Rietveld_PDF2-3\LaFeAlO3_3.gpx
> GPX file save successful
> Refinement results are in file: C:\Users\Edward\Documents\Colaboraciones\Raquel del Toro\Refinamiento_Perovskita\MyWorks\RAQ-61A\Rietveld_PDF2-3\LaFeAlO3_3.lst
> ***** Refinement successful *****
> GPX load successful. Last saved with GSAS-II version 2509
> Particularly, catches me the last line. Is it GSAS-II version 2509 or 2511?
I think the GSAS-II version is 2509.
Yushi Yang
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20161104/d5839544/attachment.html>
More information about the GSAS-II mailing list
