[GSAS-II] I can not export CIF-full in GSAS-II (Edward Ebner Avila Sosa)
Yang Yushi
yangyushi1992 at icloud.com
Fri Nov 4 02:36:32 CDT 2016
>> The GSAS-II version that I am using is 2511. Nevertheless, when I run the program and it ends, wirtes the lines down.
>> C:\Users\Edward\Documents\Colaboraciones\Raquel del Toro\Refinamiento_Perovskita\MyWorks\RAQ-61A\Rietveld_PDF2-3\LaFeAlO3_3.gpx
>> project save successful
>> Hessian refinement on 16 variables:
>> 26 derivative time 0.0020
>> matrix modification needed; lambda now 1.0e-02
>> matrix modification needed; lambda now 1.0e-01
>> Cycle: 0, Time: 0.36s, Chi**2: 6881.7, Lambda: 0.01, Delta: -4.69e-05
>> converged
>> 26 derivative time 0.0040
>> Read from file: C:\Users\Edward\Documents\Colaboraciones\Raquel del Toro\Refinamiento_Perovskita\MyWorks\RAQ-61A\Rietveld_PDF2-3\LaFeAlO3_3.bak86.gpx
>> Save to file : C:\Users\Edward\Documents\Colaboraciones\Raquel del Toro\Refinamiento_Perovskita\MyWorks\RAQ-61A\Rietveld_PDF2-3\LaFeAlO3_3.gpx
>> GPX file save successful
>> Refinement results are in file: C:\Users\Edward\Documents\Colaboraciones\Raquel del Toro\Refinamiento_Perovskita\MyWorks\RAQ-61A\Rietveld_PDF2-3\LaFeAlO3_3.lst
>> ***** Refinement successful *****
>> GPX load successful. Last saved with GSAS-II version 2509
>> Particularly, catches me the last line. Is it GSAS-II version 2509 or 2511?
> I think the GSAS-II version is 2509.
Your current version is 2511, the previous version you created the .gpx file is 2509.
I was wrong. The previous thread is stupid.
Yushi Yang
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20161104/3e782611/attachment-0001.html>
More information about the GSAS-II
