[GSAS-II] permission denied on linux after update
Toby, Brian H. toby at anl.gov
Fri Jan 13 12:38:21 CST 2017
This is controlled by the subversion repository and software. I think it is easily changed. As of version 2629 the u+x bit should be set up updates if I got it right.
I should note that this is an unusual use case. Most people start GSAS-II using some version of
	<path>/python <path>/GSASII.py
(since we don’t expect that the python found in the path will have the right packages).
Brian
> On Jan 13, 2017, at 9:49 AM, Lambert van Eijck - TNW <L.vanEijck at tudelft.nl> wrote:
> Dear gsas2 developers,
> A low-priority request:
> is it possible to add a "chmod u+x" to the update routine of Gsas2.
> Pulling the latest version makes the python scripts non-executable, and
> I get a:
> "bash: /home/lve/src/gsas2/GSASII.py: Permission denied"
> best regards, Lambert
> GSAS-II mailing list
> GSAS-II at mailman.aps.anl.gov
> https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
More information about the GSAS-II mailing list
