[GSAS-II] Generalized anisotropic strain
Peter Y. Zavalij
pzavalij at umd.edu
Thu May 4 19:18:31 CDT 2017
Corresponding equations for all crystal systems are in GSAS manual.
Peter
Peter Y. Zavalij
Director - X-ray Crystallographic Center
University of Maryland,
College Park, MD 20742
On Thu, May 4, 2017 at 5:03 PM, Riley Hanus <rhanus at u.northwestern.edu>
wrote:
> Thanks!
> I would like extract the strain value in, say the x-direction. Which is
> difficult to extract from that bit map image. Is there a way to export data
> values instead of the bitmap image?
> Or is there an equation I could use that takes S400 and S220 as input?
> Riley
> On Thu, May 4, 2017 at 1:52 PM, Toby, Brian H. <toby at anl.gov> wrote:
>> On May 4, 2017, at 12:42 PM, Riley Hanus <rhanus at u.northwestern.edu>
>> wrote:
>> I have used the generalized anisotropic mustrain model (Cubic crystal
>> system, so S400 and S220 are used). The generalized anisotropic model
>> works well in fitting the peak broadening!
>> 1) I wanted to confirm that the plot of mustrain is in strain*10^-6.
>> Meaning mustrain*10^-4 = strain %.
>> Numbers shown in data tab are strain*1,000,000 (10^6*delta-d/d or
>> equivalently 10^6*delta-Q/Q; unit-less)
>> 2) How do I either export the 3D strain plot that you can view when
>> selecting Select plot type: mustrain under the Data tab.
>> Use the “floppy disk” icon to export the plot as a bitmap image.
>> Brian
> GSAS-II mailing list
> GSAS-II at mailman.aps.anl.gov
> https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20170504/7bd556d9/attachment.html>
Type: image/png
Desc: not available
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20170504/7bd556d9/attachment.png>
More information about the GSAS-II
