[GSAS-II] Unable to load Rigid body model (Import XYZ files) for Simulated Annealing
Falenty, Andrzej
afalent at gwdg.de
Sat Sep 8 05:34:06 CDT 2018
Hi Angshuman, I looks like the old issue I have been reporting long time ago. The RB was not really working in GSASII so I dropped the whole thing and tried to use FOX instead. At the end I moved to Reitan for this kind of exercises.
Good Luck
Andrzej
Von: gsas-ii-bounces at aps.anl.gov <gsas-ii-bounces at aps.anl.gov> im Auftrag von Angshuman Gupta <angshumanmet at gmail.com>
Gesendet: Freitag, 7. September 2018 08:42:33
An: gsas-ii at aps.anl.gov
Betreff: [GSAS-II] Unable to load Rigid body model (Import XYZ files) for Simulated Annealing
Dear Sir,
I am Angshuman Gupta, using GSAS II for my research works. I was trying to do simulated annealing using GSAS II as given in example "https://subversion.xray.aps.anl.gov/pyGSAS/Tutorials/MCsimanneal/MCSA%20in%20GSAS.htm". I was unable to import XYZ atoms coordinate rigid body file requires for performing MC/SA. When I check the log file generated in terminal I got
"Traceback (most recent call last):
File "/home/laptop/GSASII/GSASIIconstrGUI.py", line 1510, in OnImportRigidBody
ImportResidueRB()
File "/home/laptop/GSASII/GSASIIconstrGUI.py", line 1579, in ImportResidueRB
text,ext = getTextFile()
File "/home/laptop/GSASII/GSASIIconstrGUI.py", line 1490, in getTextFile
wx.FD_OPEN | wx.CHANGE_DIR)
AttributeError: 'module' object has no attribute 'CHANGE_DIR' "
I will be thankful to you if you kindly suggest me whats wrong with it and how to overcome this error.
I am running GSAS on LInux Mint version 18.3 and Anaconda python 2.7.15
Thank you
Yours sincerely
Angshuman Gupta
PhD Indian Institute of Technology Bombay
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20180908/8ab46c5e/attachment.html>
More information about the GSAS-II
