[GSAS-II] Unable to load Rigid body model (Import XYZ files) for Simulated Annealing
Toby, Brian H.
toby at anl.gov
Sat Sep 8 14:20:02 CDT 2018
Bob has now repaired Angshuman’s bug (which had to do with incompatibilities between different wxPython versions) and as far as we are aware, rigid bodies are working fine. If not, please give us enough details so we can track down any other bugs.
Brian
On Sep 8, 2018, at 5:34 AM, Falenty, Andrzej <afalent at gwdg.de<mailto:afalent at gwdg.de>> wrote:
Hi Angshuman, I looks like the old issue I have been reporting long time ago. The RB was not really working in GSASII so I dropped the whole thing and tried to use FOX instead. At the end I moved to Reitan for this kind of exercises.
Good Luck
Andrzej
Von: gsas-ii-bounces at aps.anl.gov<mailto:gsas-ii-bounces at aps.anl.gov> <gsas-ii-bounces at aps.anl.gov<mailto:gsas-ii-bounces at aps.anl.gov>> im Auftrag von Angshuman Gupta <angshumanmet at gmail.com<mailto:angshumanmet at gmail.com>>
Gesendet: Freitag, 7. September 2018 08:42:33
An: gsas-ii at aps.anl.gov<mailto:gsas-ii at aps.anl.gov>
Betreff: [GSAS-II] Unable to load Rigid body model (Import XYZ files) for Simulated Annealing
Dear Sir,
I am Angshuman Gupta, using GSAS II for my research works. I was trying to do simulated annealing using GSAS II as given in example "https://subversion.xray.aps.anl.gov/pyGSAS/Tutorials/MCsimanneal/MCSA%20in%20GSAS.htm". I was unable to import XYZ atoms coordinate rigid body file requires for performing MC/SA. When I check the log file generated in terminal I got
"Traceback (most recent call last):
File "/home/laptop/GSASII/GSASIIconstrGUI.py", line 1510, in OnImportRigidBody
ImportResidueRB()
File "/home/laptop/GSASII/GSASIIconstrGUI.py", line 1579, in ImportResidueRB
text,ext = getTextFile()
File "/home/laptop/GSASII/GSASIIconstrGUI.py", line 1490, in getTextFile
wx.FD_OPEN | wx.CHANGE_DIR)
AttributeError: 'module' object has no attribute 'CHANGE_DIR' "
I will be thankful to you if you kindly suggest me whats wrong with it and how to overcome this error.
I am running GSAS on LInux Mint version 18.3 and Anaconda python 2.7.15
Thank you
Yours sincerely
Angshuman Gupta
PhD Indian Institute of Technology Bombay
GSAS-II mailing list
GSAS-II at aps.anl.gov<mailto:GSAS-II at aps.anl.gov>
https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20180908/b4f38e59/attachment.html>
More information about the GSAS-II
