[GSAS-II] Residuals
Toby, Brian H. toby at anl.gov
Sat Sep 15 09:04:49 CDT 2018
Emily,
   You can find Rwp (labeled as wR) for each histogram by clicking on each histogram in the data tree. (BTW, Rp does not mean much). Also there are the Bragg R-factors for each phase in the histogram.
   Under the Covariance tree item you can find overall statistics for all histograms. Note that what many people call Chi**2 should actually be called Reduced Chi**2. We list that using the single crystal convention, goodness-of-fit (GOF), which is the square-root of the Reduced Chi**2.
    GSAS-II does produce a .lst file, but it only contains the results for the most recent cycle of refinement — so no LSTVIEW needed; open in your favorite text editor/viewer. The .lst file has way more statistics, most of which I don’t believe in using.
Brian
On Sep 14, 2018, at 7:38 PM, Emily Siska <siskae at unlv.nevada.edu<mailto:siskae at unlv.nevada.edu>> wrote:
I am looking for the GSAS I "list view" in GSAS II. I would like to see my wRp and Rp. Where can I find these?
    Thank you!
    Best Regards,
    Emily Siska
Emily Siska
Chemistry Graduate Assistant
Chemistry/HiPSEC
Science and Engineering Building, Room 2173
University of Nevada, Las Vegas
4505 S. Maryland Pkwy.
Las Vegas, NV 89154-4003
Office: (702) 894-1478
Cell: (818) 642-7718
GSAS-II mailing list
GSAS-II at aps.anl.gov<mailto:GSAS-II at aps.anl.gov>
https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20180915/24a7a105/attachment.html>
More information about the GSAS-II mailing list
