[GSAS-II] determine profile parameter from a standard
LiaoNU liaonu at gmail.com
Mon May 20 08:42:21 CDT 2019
I just started using GSAS II to fit some X-ray diffraction patterns from a
Regaku XRD. The first thing I am doing is to fit the profile parameter
from a spectra of a LaB6 standard. The instrument is quite good so Ka2
peaks are clearly resolved for most peaks. I was wondering if I should pick
all the Ka2 peaks in peak fitting or GSAS will identify those peaks
automatically?
I have also got several incorrect fitted peaks (red/negative intensities in
the Peak List) no matter I pick those Ka2 peaks or not. Is there a way to
clean it up?  The range I am fitting is 20-145 degrees (2-theta).
I have been following this link for profile parameter fitting.
https://subversion.xray.aps.anl.gov/pyGSAS/Tutorials/CWInstDemo/FindProfParamCW.htm
Thank you.
Best,
Liao
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20190520/e4cf5e9f/attachment.html>
More information about the GSAS-II mailing list
