[GSAS-II] "Fix" to simulated pattern
Ivo Alxneit
ivo.alxneit at psi.ch
Mon Jun 24 09:00:18 CDT 2019
Dear all
I just noticed in scriptable that when you simulate a powder pattern
some sort of refinement takes place even though this should not be
needed. You can actually also "see" this in the GUI. This comes from the
defaults: "Analytical Hessian" with a maximum of three cycles. As I was
simulating thousands of patterns I spent quite a bit of time doing
unnecessary work.
So, my suggestion is to add
self.set_Controls('cycles', 0)
to add_simulated_powder_histogram() in GSASIIscriptable.py (and probably
to the appropriate place in the GUI too) to prevent any iteration for
simulated pattern.
gruss ivo
Dr. Ivo Alxneit
Catalysis for Energy Group
Bioenergy and Catalysis Laboratory phone: +41 56 310 4092
Paul Scherrer Institute fax: +41 56 310 2688
CH-5232 Villigen gnupg key: 0x515E30C7
Switzerland
https://www.psi.ch/ceg/
Desc: OpenPGP digital signature
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20190624/581db4dd/attachment.sig>
More information about the GSAS-II
