[GSAS-II] "Fix" to simulated pattern
Von Dreele, Robert B.
vondreele at anl.gov
Mon Jun 24 10:01:31 CDT 2019
A good idea – implemented for GUI case of making simulated data; max cycles = 0
Bob
Sent from Mail<https://go.microsoft.com/fwlink/?LinkId=550986> for Windows 10
From: Ivo Alxneit via GSAS-II<mailto:gsas-ii at aps.anl.gov>
Sent: Monday, June 24, 2019 9:04 AM
To: gsas-ii at aps.anl.gov<mailto:gsas-ii at aps.anl.gov>
Subject: [GSAS-II] "Fix" to simulated pattern
Dear all
I just noticed in scriptable that when you simulate a powder pattern
some sort of refinement takes place even though this should not be
needed. You can actually also "see" this in the GUI. This comes from the
defaults: "Analytical Hessian" with a maximum of three cycles. As I was
simulating thousands of patterns I spent quite a bit of time doing
unnecessary work.
So, my suggestion is to add
self.set_Controls('cycles', 0)
to add_simulated_powder_histogram() in GSASIIscriptable.py (and probably
to the appropriate place in the GUI too) to prevent any iteration for
simulated pattern.
gruss ivo
Dr. Ivo Alxneit
Catalysis for Energy Group
Bioenergy and Catalysis Laboratory phone: +41 56 310 4092
Paul Scherrer Institute fax: +41 56 310 2688
CH-5232 Villigen gnupg key: 0x515E30C7
Switzerland
https://www.psi.ch/ceg/
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20190624/1121033f/attachment.html>
More information about the GSAS-II
